H22 wiring in a f22a1 automatic Accord?
Old Feb 20, 2003 | 06:43 AM
Desperado's Avatar
Default H22 wiring in a f22a1 automatic Accord?
I had did a search and came up with nothing. I need a link or a diagram on how to wire vtec in an Accord. Also if anyone has the information how to convert an auto to 5 speed write up?
Old Feb 20, 2003 | 06:52 AM
altoid's Avatar
Default Re: H22 wiring in a f22a1 automatic Accord? (Desperado)
hmm, h22 head won't fit on any accord...and there are lots of auto to manual conversion posts check out the archives i'll look up some stuff
just search the archives and type in auto manual in the field, lots of stuff
[Modified by EE4, 10:59 AM 2/20/2003]
Old Feb 20, 2003 | 07:00 AM
4g4me's Avatar
check this out.... you should install the h22 just like the f-series came out. The wire it up like it was a non-vtec. Add a vtec controller i.e. rpm switch, then get your rev limiter raised or removed.
Or you could just get a prelude automatic ecu, then run wires for your knock sensor, vtec silenoid, oil pressure switch, and anything else that the accord deonst have that the prelude does. (which isnt much)
Old Feb 20, 2003 | 08:18 AM
Desperado's Avatar
Default Re: H22 wiring in a f22a1 automatic Accord? (4g4me)
I apreciate it, thanks.
korndog
Oct 30, 2007 04:12 PM
mvaccoRd
Jan 13, 2004 07:57 PM
tylek17
Dec 19, 2003 08:17 AM
eg686
Oct 26, 2003 08:40 PM
