shieTT!!!miss shift and hit over 8 1/2
Old Feb 19, 2003 | 11:41 PM
HmgLauj69's Avatar
Default shieTT!!!miss shift and hit over 8 1/2
it was today, i was racing a friend of mine....freakin miss shift 4th, don't know how that f@#$!!! i did that....my rpm went way pass 8 1/2 (no internal upgrades), scared the shiet out of me....steped on the clutch hella fast....fo sure my valves needs adjustment, but how would i check to see if my pistons or anything else inside the motor if f@#$ed!!??
Old Feb 19, 2003 | 11:53 PM
Volcom's Avatar
Default Re: shieTT!!!miss shift and hit over 8 1/2 (HmgLauj69)
how does it idle? rough, you might have done some damage. If not, you might have gotten lucky. What kind of car?
aznmc16's Avatar
u only hit a lil over 8500RPM? man i've hit over 9000RPM ( i think 9500RPM ) and my car is still fine. scared the lving **** outa me though..
Old Feb 20, 2003 | 12:15 AM
HmgLauj69's Avatar
Default Re: shieTT!!!miss shift and hit over 8 1/2 (Volcom)
94 ls(red-line at 6900), at idle it sounds norm but that's right after the race...the check egine light is not on thats a good sign...is thea anything that i could've damaged?!
Old Feb 20, 2003 | 12:33 AM
Loveless's Avatar
haha, today I was driving normal and I missed shifted into 1st gear instead of 3rd gear but I knew a head of time and stepped on the clutch so my rpm only went up to 3k, no biggy.
Old Feb 20, 2003 | 12:43 AM
ahead's Avatar
Default Re: shieTT!!!miss shift and hit over 8 1/2 (Loveless)
howd you do that?? my gsr locks me out of 1st when im driving, its not imposible to put in 1st but you have to try to put it in????
Old Feb 20, 2003 | 12:51 AM
PoW3l2BaN's Avatar
you may not need to worry cause the factory rev limiter saves you.
Old Feb 20, 2003 | 12:54 AM
HmgLauj69's Avatar
Default Re: shieTT!!!miss shift and hit over 8 1/2 (ahead)
man! quit shieting around!! if ya'll wanna talk bout them stuff do it some wea else!! READ THE ORIGINAL POST!!! it did not ask for any of those bs!!....alright now, it was around 11 pm yesterday, was racing a friend of mines and miss shifted rpm climed all the way past 85000....i have a 94 ls which red lines at 69000 and ends at 85000....scared the **** out of me when that happened....i know for sure my valves needs adjustment....but don't know what else is f@#$ed!!...it's normal at idle just little ticks(more like clicks) bout it....could thea be other shiet f@#$ed inside my notor????.....and how would i check them???
[Modified by HmgLauj69, 9:54 AM 2/20/2003]
[Modified by HmgLauj69, 9:55 AM 2/20/2003]
Old Feb 20, 2003 | 12:55 AM
ahead's Avatar
Default Re: shieTT!!!miss shift and hit over 8 1/2 (PoW3l2BaN)
not when you miss-shift. the rev-limiter cuts the fuel when your accelerating. if you miss-shift the rev limiter is bypassed and your motor can rev till it explodes. goodluck
Old Feb 20, 2003 | 12:56 AM
ahead's Avatar
i dont have much experiance with this but im guessing at most you bent a few valves but since your saying your idle isnt rough you may have lucked out. go get your valves checked out and goodluck
Old Feb 20, 2003 | 01:56 AM
mey_xanng's Avatar
Try these sites, since mis-shifting is a driver error
http://www.turnfast.com/tech_driving...shifting.lasso
and
http://www.shortshifter.com/techniques2.htm
Old Feb 20, 2003 | 02:03 AM
Loveless's Avatar
what if I like to shiet around wea I don't want to stop? a friend of mines wasn't racing with me but I still managed to get my rpm to 85000 while my gauge cluster's limit is 69000 rpm meaning the needle went around the gauge 3 times and end at 85000 and my valves just eject after I push the jdm rice button but the parachutes didn't depoly so they are @#$ed!!... and will not fit in my notor anymore.
[Modified by Loveless, 5:21 AM 2/20/2003]
Old Feb 20, 2003 | 04:53 AM
JumbosGS-R's Avatar
New User
What do you own a jet? 85000 huh? and 69000...do your self a favor and every one else for that matter, proof read your response before you hit POST.
[Modified by JumbosGS-R, 8:54 AM 2/20/2003]
Old Feb 20, 2003 | 04:57 AM
Eva01's Avatar
Default Re: shieTT!!!miss shift and hit over 8 1/2 (JumbosGS-R)
First of all, I would check the CEL and find out what code it's throwing. That should help hunt down any possible damage.
Old Feb 20, 2003 | 04:59 AM
Loveless's Avatar
that was a response to HmgLauj69's rude behavior and typos/mistakes. The bolded texts are the apparent errors.
[Modified by Loveless, 5:59 AM 2/20/2003]
JBBNJ609's Avatar
this happened to me when i first got my license , i got super scared and i thought the engine was making a noise ( all in my mind) , i went got a copression test , and leak down and visual inspection of valves and such , everythign was fine except i DID need a valve adjustment ( i did one of those , 3rd gear red lineing clutch down , shifting the 4th , Fuct up and hit 2nd , made a crazy nosie , but picked it up about a half a second after it went in ) it sucked o yea p.s. there is no rev limiter when you misshift , its like being past it so it doesnt save you . . . . .
[Modified by jason bouchard, 2:00 PM 2/20/2003]
[Modified by jason bouchard, 2:08 PM 2/20/2003]
Old Feb 20, 2003 | 05:16 AM
JumbosGS-R's Avatar
New User
No I know just I used your response because you put the mistakes in bold so thats what I was pointing out.
Old Feb 20, 2003 | 05:22 AM
RockDawg_GSR's Avatar
Default Re: shieTT!!!miss shift and hit over 8 1/2 (jason bouchard)
Hopefully you lucked out!I missed 4th and put it in 2nd , rpm's shot to 9k, but i slammed the clutch pedal down hoping to save me. . But unfortuneatly i bent 2 valves and banged up 1 of my valve guides. So i replaced my whole valvetrain .Just uh..Make sure you are not out driving around still, and get it checked soon.Try to see if it is pulling any codes.Right afer it happened for me, it idled really bad, bogging and wanting to stall.Head was sent out to machine shop and magnafluxed for any cracks and shiet that may have ruined the head.Luckily nothing major was done and i could keep it. Still driving with over 120,XXX miles and still whoopin' dem stangs.
Old Feb 20, 2003 | 07:08 AM
EvilIntegrationLS's Avatar
yea, my LS locks me outta 1st gear till i'm going about 5-10 mpg or rolling, i can't put mine into 1st from 3rd if i TRIED.
Old Feb 20, 2003 | 07:10 AM
Default Re: shieTT!!!miss shift and hit over 8 1/2 (Eva01)
but if the idel is normal, and your car is running fine, idles fine, and still feels smooth from gear to gear, then you should be alright. check for any burned oil or anything coming from your exhaust too, that might indicate valvetrain problems or other internal problems.
Old Feb 20, 2003 | 07:54 AM
HmgLauj69's Avatar
Default Re: shieTT!!!miss shift and hit over 8 1/2 (RockDawg_GSR)
yeah!?....right after it happened to me it was idleing somewhat normal...ima bout to check it again right now....but most likely it's just my valves right??......could my pistons be f@#$ed too??.....remember i gots a 94 ls with 153,XXX miles on it, red lines at 6900 my rpm jumped over 8500....now that's bad considering it's an 94 ls that's over mile....
my bad bout the post the other day, people just be posting some stupid shiet sometimes.....and ya'll know how it is when this kinda stuff happens....mad as a mother....so yeah, no hard feeling though ya'll!....
[Modified by HmgLauj69, 4:59 PM 2/20/2003]
Old Feb 20, 2003 | 08:05 AM
drumking15's Avatar
Ya, ive done the same...well it think everyone has...my story goes i was racing a prelude through downtown boston, went to throw it in 5th...oops 3rd gear forced rev it way over 10g's...and mine survived!!! Must be to all those good oil changes every 2500 miles that my motor wanted to live or something...just readjust your valve lash and you should be alright.
Old Feb 20, 2003 | 10:47 AM
B00ST2nR's Avatar
Default Re: shieTT!!!miss shift and hit over 8 1/2 (drumking15)
I thought you hit 8500rpm in a GS-R... but since its on an LS, there MIGHT have been some damage. If you're lucky, maybe not.
How's the car running? Idle? Any difference in the drive? Go test your car out and see if anything is different and let us know. Then we can probly help you out a little bit more.
Old Feb 20, 2003 | 10:53 AM
jaM3s Bond's Avatar
Default Re: shieTT!!!miss shift and hit over 8 1/2 (Skunk2nR)
Maybe you should relax when you shift.
Old Feb 20, 2003 | 11:45 AM
MRXMUFFIN's Avatar
dont worry too much man. is your car running funny or is there a funny smell or smoke somewhere? my friend somehow went from 5th to 3rd and did 10,000rpm (i think thats where the rpm ends, the needle couldnt go any higher) in his gsr. He was in it for about 3 seconds due to all of us yelling at him and pointing to his tach. But his car is fine.
