Adjustable endlinks for the ITR sway bar???
There would definately be plus to using them, and correctly setting/equalizing the load on the bars after the car has been cornerweighted.
That being said, I haven't seen any but have purchased a spare set of front links for just this purpose.
The rears might be a little tougher to work with, and all four will need to be re-worked just to be usable in an adjustable manner.
If you just wanted to equalize the loads - couldn't just one adjustable endling on each bar accomplish this?
I use Heim joints(rod ends if that what you are thinking about) as adj endlinks on my type-r bar...my car is in storage I'll see if I can grab a pic for you.
Thanks, though at this point the adjustable links are not presently high on my need-to-do list.
That being said ... once the car is up and running with the buddy clubs and fresh rear springs installed,
I'll be looking into optimizing the suspension.
onsetofpurity
Jan 9, 2008 06:00 AM
