How can you tell if your clutch is going out?
Old Feb 19, 2003 | 09:40 PM
soloIntegra's Avatar
Default How can you tell if your clutch is going out?
Hi,
I was wondering if any of this happens to you guys. I have a 2001 integra gsr and sometimes when I lift my foot off the clutch after shifting it sometimes sticks to the floor for a second or the pedal does not spring back up. I was wondering if my clutch was going out or is this just the way that clutches get broken in. I hope I explained this problem correctly.
Thanks for any help.
Old Feb 20, 2003 | 01:09 AM
integobsession's Avatar
Default Re: How can you tell if your clutch is going out? (TpMenace)
I read on here a few weeks ago that lets you do something to test to see if your clutch is slipping... but i forgot... lemme search for it real quick.
Old Feb 20, 2003 | 01:14 AM
Default Re: How can you tell if your clutch is going out? (integobsession)
sorry I tried to find it with no luck... it's pretty late in the evening so perhaps i over-looked it... but i'm sure there's plenty of people here that knows how to tell if it is indeed your clutch and not something else...
Old Feb 20, 2003 | 02:31 AM
Loveless's Avatar
Basically, when you pushes on the pedal, the gears grind when shifting into first or reverse (from a stop, with the engine running), rather than going into gear.
I think your problem is something else.
Old Feb 20, 2003 | 02:36 AM
ebelp's Avatar
Default Re: How can you tell if your clutch is going out? (Loveless)
This sounds more like a clutch master/slave cylinder problem. Right before the clutch sticks to the floor, does it go down with almost no resistance?
XenonDepot's Avatar
Put your car in fifth gear and approx 2000 RPM. Floor the car.
If you feel your clutch slip then you know its going.....
Regards,
Steve
Old Feb 20, 2003 | 03:24 AM
96integra20's Avatar
Default Re: How can you tell if your clutch is going out? (XenonDepot)
See now i heard different, i heard if you put your car in 5th gear and then when standing still with the car idling, let go of the clutch, if the car stays running....your clutch is shot, if it dies out then its all good. i actually learned something in school.
Old Feb 20, 2003 | 05:15 AM
Eva01's Avatar
Default Re: How can you tell if your clutch is going out? (ebelp)
Try checking the fluid level in your clutch resevoir. If it's low or empty...quite possibly you've got a leak in master/slave cylinder. Another sign of a leaky master cylinder, look for leakage at the firewall where the clutch goes in. HTH
Old Feb 20, 2003 | 07:19 AM
EvilIntegrationLS's Avatar
Default Re: How can you tell if your clutch is going out? (Eva01)
clutch slipping = when you press on the gas, clutch is depressed, and your rpm's jump higher than normal, but you see no significant increase in excelleration.
almost feels like your revving your motor, but the clutch is engaged and in gear.
Old Feb 20, 2003 | 07:23 AM
Default Re: How can you tell if your clutch is going out? (EvilIntegrationLS)
does sound like your clutch slipping at all, sounds like a master cyclinder/slave problems, or possibly the clutch fork??? i dunno.
i know sometimes when i clean my interior and do the carpets, i accidently put the floor mats too close to the firewall after i clean them, and they're curled upwards, so when i press the clutch, and then go to depress, then clutch gets stuck behind my floor mat for half a sec. rrrrrr
Old Feb 20, 2003 | 07:52 AM
Teg4e's Avatar
I had this same problem when I first got my teg, make sure your carpets are all the way against the seat. hopefully that's your problem and not a clutch issue.
alfaaay
Mar 31, 2003 11:57 AM
JDEM1
Jan 28, 2003 11:07 PM
JMU R1
12
Sep 26, 2001 09:39 AM
JMU R1
Sep 17, 2001 12:20 PM
