can i see some exhaust pics?
I'm sick of the exhaust I have now, so its off, and now I'm getting sick of the open downpipe...
so, can you guys post some pics of your exhausts, so i can get an idea of what certain ones look like on...
TIA
Kevin
TIA
Kevin
Thats the ultimate sleeper exhaust!
Exactly how did you do that? Is the a big hole at the top of the stock exhaust to fit the Magnaflow in there? Seems like that would be a lot of work.
Yes, Brad please explain how you did that cause I would really like to know. What part of San Jose you from? If its possible maybe you can show me or tell me where you got it done.
I'm curious for you guys who say the ES Oval is good, what is the sound level like...no one wants that coffee can noise...
Kevin
Kevin
you might be in Luck I have an ITR axleback exhaust if anyone is looking for a new one
https://honda-tech.com/zerothread?id=417483
there is the thread, hit me up
It's pretty much a cut and paste job. I cut the back end out and the pipe sticking out front (tip side) with a sawzall and drill, then I pulled out the insides of the stock muffler. I used a 14" offset/center magnaflow in and tack welded it in place inside. It's sort of positioned upwards at an angle. The pipe sticking out the front is a 2.5" piece that I had crush bent to resemble the stock pipe thought the rest of the exhaust is mandrel bent. I tack welded the tip on and welded the other end to the rest of the exhaust and that's about it.
It's not as quiet as I'd like even though it also has two other 14", 22" round magnaflow mufflers used as resonators, and a cat and turbo. It's like in the middle between a greddy SP and a thermal 3".
Brad
Brad
