gotta get car smogged at a test only (type r engine in an RS), need help
Old Feb 19, 2003 | 08:40 PM
NWPNOMORE's Avatar
Banned
Default gotta get car smogged at a test only (type r engine in an RS), need help
I know I need to have every single emissions sensor in tact to pass the test, I guess there are 24 the computer test checks for. Well I have a 1996 RS, with a 98 udsm type r motor and when I run the type r ecu I get codes because I'm missing a sensor or two (type r's have a sensor that my car doesn't). I have a jdm ecu in my car right now, but that doesn't communicate with the computer they use for smog. I have to go to a test only place and I'm trying to figure out which ecu I can use to make sure everything goes smoothly. Anyone have and advice or experience with the situation? Thanks
[Modified by NWP4LIFE, 9:47 PM 2/19/2003]
Old Feb 19, 2003 | 08:45 PM
NWPNOMORE's Avatar
Banned
Default Re: gotta get car smogged at a test only (2dark2bslow)
sounds like an illegit motor to me
p.s. could be wrong though
why do you say that?
Old Feb 19, 2003 | 08:48 PM
Casey's Avatar
Default Re: gotta get car smogged at a test only (NWP4LIFE)
his title says it all dont be an ***, n00b. id try and figure out which sensors arent hooked up, if that doesnt work, money talks
Old Feb 19, 2003 | 08:49 PM
sa21199's Avatar
you get codes with the usdm ecu or jdm ecu??
Old Feb 19, 2003 | 08:52 PM
B2FiNiTY's Avatar
Default Re: gotta get car smogged at a test only (sa21199)
He gets codes with them USDM ITR ecu so he's runningt the JDM ecu.
Old Feb 19, 2003 | 08:53 PM
NWPNOMORE's Avatar
Banned
i get codes from the usdm ecu, code 91 (i was told itr's have a sensor in the gas tank that my car doesn't have), the jdm ecu is code free but can't be used with CA's smog computers.
Old Feb 19, 2003 | 09:08 PM
fowler!'s Avatar
I've heard that 97 obd II ecus don't look for that sensor in the gas tank. I'd look into that...try and find someone local that will hook it up.
Old Feb 19, 2003 | 09:12 PM
TypeR 599's Avatar
are you serious?? i was going to get smogged tomorrow with the jun ecu...crap, i got to find a 98..
Old Feb 19, 2003 | 09:13 PM
NWPNOMORE's Avatar
Banned
Default Re: gotta get car smogged at a test only (TypeR 599)
yeah, u better find a usdm ecu, jun ecu definitely won't work.
Old Feb 19, 2003 | 09:16 PM
TypeR 599's Avatar
so they're going to check my ecu too? if they don't, how do they know i have a jdm ecu?
fowler!'s Avatar
JDM ecu has an OBD1 program. That won't jive well with their equiptment.
Old Feb 19, 2003 | 09:18 PM
JDM CTR '00's Avatar
i never seen them check the computer.
NWPNOMORE's Avatar
Banned
they hook up their computer with yours. They won't know you have a jdm ecu. When I tried they thought they had a problem with their equipment so they called Sacramento. I knew what was the problem and just got out of there.
Old Feb 19, 2003 | 09:22 PM
fowler!'s Avatar
Default Re: gotta get car smogged at a test only (ChargedSi99)
They don't check the actual ecu, they plug in their junk to this thing right by your coin holder.
I forget what they call it..
Old Feb 19, 2003 | 09:23 PM
GreenD's Avatar
a 97 itr ecu is the way to go. im using a 98 itr ecu in my 97 gsr and im getting a 91 also.
could u use a 96-97 gsr or b16 ecu for the test??
Old Feb 19, 2003 | 09:24 PM
Default Re: gotta get car smogged at a test only (fowler)
they did not do that to me. Th e last 3 times i did this
Old Feb 19, 2003 | 09:26 PM
B2FiNiTY's Avatar
I forgot what it is called too but it basically controls everything in your car and can check for codes.
Old Feb 19, 2003 | 09:27 PM
TypeR 599's Avatar
Default Re: gotta get car smogged at a test only (B2FiNiTY)
so my jun ecu won't comply with their machine? i dont throw any codes either.
Old Feb 19, 2003 | 09:31 PM
fowler!'s Avatar
The last time I got my car smogged, I watched as he plugged his thing into my car. I'm not sure how they do it where you go, or if they do it at all, I'm only speaking from experience.
From what I understand, because it's OBD 1, that won't work with their equptment..even if you aren't getting any codes. You can try it, but I'll bet a few bucks you'll fail based on your ECU.. after all, it's part of the emissions junk..
It's getting late, I can't put words together...
Old Feb 19, 2003 | 09:41 PM
TypeR 599's Avatar
damn.. thanks craig
Old Feb 19, 2003 | 10:52 PM
98itR484's Avatar
I got a USDM ITR ECU for hire if anyone wants to use
JDM_JUNKIE_DA
Nov 4, 2009 04:24 PM
NewYorkTypeR
Jul 30, 2001 11:54 AM
