someone please help me with my problem
alright ive posted before, and i ahvent gotten any repsonses and i decided to deal with it, but now it is so bad . . im driving my self insane.. . when i stat my car, it makes a loud EEEAR , a high pitch screetching noise, whihc sounds like a belt starting to turbn adn what not. . .i had my friend start the car when i wa slistening under the hood and it was almost deafening. when i start it in a parking lot, literrally anyone in the parking lot will hear and be liek WTF was that?? it used to go away if my car had been on mroe thna 5 minutes, then starting it. . but no matter how warmed up my car is, all i needs is about 15 or 20 minutes to sit and it will sqeak nice and loud. also recently it will squeak when it cranks up, and then stay squeaking. . so id rev it and it would go away, and tonight i went to the gas station and when i started it it sqeaked and stayed on, and i reved it but it kept squeaking obnoxiously loud eveyrone was watching me. . i reved it up to 6 thosuand for two second and when i came back down it finally went away. . its getting worse and worse byt he day, the previous owner said they rteplced all the belts at the 90k mile tuneup,m whihct hey showed a reciept for, so i dont know what to say or think. any help would be good do i need to replace my belts, i cant figure out which one it is i tested the tension in all of them and they are all the same. im pretty muhc stumped. how muhc do all new belts cost?
thanks. .
thanks. .
check the tention on ur belts, i might be to tight, try to loosen it, or if you dont know how to loosen belt just bring it to a garage, should take bout 15 min to adjust it.
it may be the pulleys...open the hood while its sqweaking and spray one pulley at a time w/ wd-40 or sumthing until the sqeaking stops
hope it helps
hope it helps
Yea man, first thing that came to mind wwhile i was reading your post was alternator belt. Just check the tension on your belts and see if they are too loose/tight and adjust accordingly. That should solve your prob
Please follow up and let us know how it goes!
if u check all of ur belts and take care of them already and it still sqeak, im pretty sure its ur altanator, its loose, w/ missing screws, its like the altanator is hanging or something. It happen to mine after i changed all my belts and water pump and stuff like, then like the day after i went driving around and then a screw fell off to the street, and i heard it i stoped and went and pick it up..haha.. its about 4-5 inches long. The the noise start happening like an hour later, it start sqeaking like a mU@tHEr f*cK^r!, it drives me nuts!...same exactly like urs. i took it back to the shop, the guy that did my timing belts and stuff, he checked and he said that a screw were missing, he's like, its about 5 inhes long, i was like "hey a screw fell off the other day!" i gave it him, he said yeah thats it! he said luckly u pick it up this thing are hard to get! and i was like its ur guys fault thats it wasnt tight enough. He put it back on and the noise went away!. i was happy
. ahha..but sorry for the long story i tend to go on. i like alot of example, so it'll be clear
..hope that could help somehow.
bsivoljr
Jun 21, 2007 11:44 PM
NoahOneill
19
Nov 7, 2005 10:13 AM
rasinhell
Mar 13, 2005 11:47 AM
peiku
May 13, 2004 09:18 AM
