how to disassemble the door panel
Old Feb 19, 2003 | 03:34 PM
mcchen's Avatar
Default how to disassemble the door panel
my 97 itg driver side door was locked up last night, i coundn't even open it with the
car key, it's ok this morinig. i'm thinkin about taking off the inside panel to see what's going wrong, anybody expericed it? anyhelp will be appreciated!!
Old Feb 19, 2003 | 03:57 PM
x00gsr's Avatar
Default Re: how to disassemble the door panel (mcchen)
Roll down windows open the door. 3 screws to take off. One is located in the handle of the door. 2nd is a black plastic screw a couple of inches under the driver mirror. 3rd is behind a small cover of door lock handle. Remove door lock handle. disconnected power lock. Use flat head to pry door panel. Lift door panel up and at 45 degree to take off panel.
Old Feb 19, 2003 | 05:35 PM
reno96teg's Avatar
not sure where you're located, but could it be ice in the lock? (could you unlock from the inside?)
[Modified by reno96teg, 9:38 PM 2/19/2003]
Old Feb 19, 2003 | 06:18 PM
Fuuma0083's Avatar
Default Re: how to disassemble the door panel (reno96teg)
Helms Manual
Old Feb 19, 2003 | 06:29 PM
Davanca's Avatar
I had the same prob. Your lock is just frozen, thats if you live in the Jersey,CT,VA, PA area. Or Colorado, or somewhere cold. If not then you probably have a lock problem. My lock was so frozen here in jersey that i could't even move it from the inside, after i was forced to climb in from the trunk.
Old Feb 19, 2003 | 06:31 PM
Eva01's Avatar
Default Re: how to disassemble the door panel (Fuuma0083)
Here you go mang: Step by Step w/ Pictures
HTH
Old Feb 19, 2003 | 06:55 PM
tC_Dragon's Avatar
Default Re: how to disassemble the door panel (Eva01)
HTH
gotta love the articles on team-integra.. i swear it answers so many of the repeated questions on this board. haha..
Old Feb 20, 2003 | 03:57 AM
Eva01's Avatar
Default Re: how to disassemble the door panel (pdcdragon)
No doubt. I reference stuff from that site daily.
RealRaw
Sep 2, 2020 05:22 PM
nismogrendel
Jan 26, 2013 07:34 PM
suhteevin
Jan 6, 2009 09:04 PM
itsmedavid
Aug 9, 2007 03:19 PM
Matt300ZXT
Jun 6, 2007 06:12 PM
