can i use this 93 integ stuff on 90 integ......
can i use this 93 integra stuff on my 90 integra......bumper,front fenders, hood, front windshield, driver side rear quarter window, sunroof glass... i know the bumpers need a little work but what about the rest?...thanx
Guest
Posts: n/a
Most All DA stuff is interchangible... YOu may have to up date you mounting brackets if you are trying to mount something from a 92-93 back to a 90-91. Also look at Ther DB2 and DB4 bodies
all of those parts swap over perfectly.
the only one of concern is the bumper. If you are putting a 92-93 bumper cover on your 90-91 then you'll need to cut the foam from your 90-91 bumper so it'll fit in the 92-93 bumper cover. Or you can use the 92-93 foam if it comes with it. If you are putting a 92-93 bumper cover and support (the metal behind the bumper cover) then you'll also need 92-93 bumper support brackets. The 92-93 bumper support will NOT bolt up to your 90-91 brackets.
uberEFtuner
Welding / Fabrication
Mar 26, 2011 09:59 PM
Endless STi
Nov 11, 2004 04:45 PM
Aphrodavid
Apr 10, 2004 01:19 AM
4inspeed
Oct 30, 2003 11:41 AM
Giuseppe
Jun 8, 2002 03:28 AM
