all motor set up, need imput
Old Feb 19, 2003 | 07:50 AM
typeRicer hater's Avatar
Default all motor set up, need imput
i was talking to a local performance shop that is very good about an all motor set up on my 2000 ITR. first off i already have aem cai, toda headers, apexi N1 cat-back, and clutch/fly.
he told me he would do the a complete head on the car
toda spec b's
toda cam gears
toda valve springs/
ti. retainers
toda head gasket
toda oil pump gear
port and polish
with the buddy club ECU
now that all sounds very nice but i thought that if you do that kinda work there was a couple other things you had to do like bigger injecters, sleave the block, maybe fuel rail or something.
need the imput guys if this set up is fine to run as is i am going to get a.s.a.p.
but if there is a couple of MUST HAVE's to be reliable please let me know.
thanks
Old Feb 19, 2003 | 07:55 AM
Chris N's Avatar
Default Re: all motor set up, need imput (typeRicer hater)
1. Hondata or PowerFC, not a chipped ecu.
2. Definitely an FPR.
3. Might as well get prelude injectors.
4. I think the stock fuel rail is sufficient.
Just MO.
Old Feb 19, 2003 | 07:58 AM
Default Re: all motor set up, need imput (Chris N)
but other than the FPR everything will be fine to run as a daily driver(but still babied) and 93 octaine
sorry for being so paranoid but after dropping all this money into my car my warrenty is gonna be out the door and so will my money so i want to be 110% sure
Old Feb 19, 2003 | 08:07 AM
Chris N's Avatar
I'm not the expert to give you 'definitive' answers.... there are many more experience/qualified people on here who can offer more assistance.
But, I'd say since your compression would be mid 11.x:1, 93 octane would be ok. I'd really consider some engine management besides a chipped ecu, though.
Old Feb 19, 2003 | 08:23 AM
MARC P's Avatar
I would also replace the timing belt, other than that it sounds like a nice setup.
Old Feb 19, 2003 | 08:42 AM
sgT's Avatar
sgT
Default Re: all motor set up, need imput (MARC P)
get a better timing belt
dont bother with the oil pump gear
why go with Bs? get Cs instead
Old Feb 19, 2003 | 11:06 AM
obd2gsr's Avatar
instead of the toda oil pump gear, get a PE timing belt if you're going to be using toda cams.
Old Feb 19, 2003 | 11:48 AM
Mires's Avatar
Default Re: all motor set up, need imput (obd2gsr)
Definitly get an engine management system and get it tuned by a good tuner on a dyno. You have to remember that dyno tuning is a modificaton.
Old Feb 19, 2003 | 11:49 AM
gary201147's Avatar
toda spec b's
toda cam gears
toda valve springs/
ti. retainers
toda head gasket
toda oil pump gear
port and polish
thanks
Why Toda Head gasket? That will LOWER you compression rather than raise it. Go with spoon or mugen. I like the setup, its probably what I am gonna go with when i save enough money.
Old Feb 19, 2003 | 11:51 AM
gary201147's Avatar
Default Re: all motor set up, need imput (sgT)
I know this question has been asked before but arent C's a little less streetable? I've always wanted cams but I thought that Bs would be more practical. And with his compression he is lookign only at 11.0. Wont C's be overkill to the point that Bs would be better?
Old Feb 19, 2003 | 11:53 AM
sgT's Avatar
sgT
Default Re: all motor set up, need imput (gary201147)
Why less streetable? What makes them less streetable?
Old Feb 19, 2003 | 01:29 PM
AJ PwR's Avatar
I always like easy tuning setup.
Toda B or Jun 3 cams with it's valvetrain
Ti retainers
camgears
Spoon/Mugen head gasket (why Toda ? Its not gonna raise the CR)
Hondata or chipped P28 with BC computer for fine tuning
For the above setups you don't have to worry fuel so FPR/fuel pump and bigger injectors are not necessary.
Good luck
[Modified by AJ PwR, 2:29 PM 2/19/2003]
CHEETAH's Avatar
toda spec b's
toda cam gears
toda valve springs/
ti. retainers
toda head gasket
toda oil pump gear
port and polish
1) pull your head off and mill it 30 thousandths of an inch
2) have valvetrain installed = toda springs and Titanium retianers
3) use spec C cams with adj cam gears
4) get an obd2-1 ecu harness and OBD1 P28 ecu
5) send the P28 ecu to me to reprogram
forget the port polish crap, spend that money on pistons and rods ... and don;t mill head if you upgrade or plan to upgrade to higher compression pistons.
Greg
Old Feb 19, 2003 | 01:32 PM
BoBo Racing's Avatar
this is typeRicer hater, i am on my buddy's name,
ya i am gonna go with the hondata(unsure about what stage though)
and i forgot the write that he is giving me the toda timing belt too.
so other than that the set up sounds good and i also heard the spec C's arent good for daily driven and it has a ruff idel too. puts to much strain on the motor. but that i was i heard, but i would be the first one to bow down to the knowledge of sgt.
thanks for the imput guys
for all
Old Feb 19, 2003 | 01:37 PM
NSX Bob's Avatar
New User
Default Re: all motor set up, need imput (rsx veilside)
Spec C's and Spec B's have the same primary lobes. If you can make B's idle, you can make C's idle.
Old Feb 19, 2003 | 01:41 PM
JDMb18civic's Avatar
Default Re: all motor set up, need imput (Itr00-1374)
good set of a header works even with stock ITR cams
Old Feb 19, 2003 | 01:42 PM
baonest1's Avatar
stage 3 man........
im hitting 12's soon. (i hope)
Old Feb 19, 2003 | 02:08 PM
Misfit's Avatar
Default Re: all motor set up, need imput (JDMb18civic)
he is using a toda header.....
Old Feb 20, 2003 | 07:49 PM
Default Re: all motor set up, need imput (MISFIT)
ok thanks for all the imput guys i am still not sure now about the spec b's or c's but i am gonna go with the stage 3 hondata and one other thing, which head gasket should i go with???
thanks for all the help let you know when it is done!
HaNgTiZZy
May 9, 2009 09:16 AM
hrs-parker
15
Feb 17, 2008 10:17 AM
EGkid
80
Jul 20, 2004 04:07 AM
daNk9
Feb 19, 2004 03:48 PM
sneakychaos
Nov 5, 2002 11:07 AM
