How much HP/TQ has been made with DRAG turbo kit???(Please post Dyno sheets)
Old Feb 19, 2003 | 06:49 AM
magicwand's Avatar
Default How much HP/TQ has been made with DRAG turbo kit???(Please post Dyno sheets)
I want to know how much power has been made with Drag"s turbo kit. I want to know who has made big numbers with the supplied turbo , intercooler , and piping. Please supply dyno sheet and setup if you can or will. I'm trying to find out how much I can make before the turbo and I/C holds me back. My engine is B20 VTEC THANKS..
[Modified by magicwand, 8:55 PM 2/19/2003]
Old Feb 19, 2003 | 11:56 AM
magicwand's Avatar
Default Re: How much HP/TQ has been made with DRAG turbo kit???(Please post Dyno sheets) (magicwand)
anyone?
Old Feb 19, 2003 | 12:12 PM
J.R.'s Avatar
bump for you
Old Feb 20, 2003 | 07:09 AM
magicwand's Avatar
Default Re: How much HP/TQ has been made with DRAG turbo kit???(Please post Dyno sheets) (96b18c1vic(T))
upup
Old Feb 20, 2003 | 07:13 AM
B20-T's Avatar
bump for you...jus dont boost over 10psi that what i heard ..b20 sleeve arent all that strong..stay between 7-9psi..with good fuel management .
Old Feb 20, 2003 | 01:06 PM
magicwand's Avatar
Default Re: How much HP/TQ has been made with DRAG turbo kit???(Please post Dyno sheets) (B20TURB0)
I plan on using GE sleeves
Old Feb 21, 2003 | 08:44 AM
magicwand's Avatar
anybody???
Old Feb 21, 2003 | 08:52 AM
falcongsr's Avatar
What is this crap?
so you're going to have the motor built huh? can you tell us more about your setup?
Old Feb 21, 2003 | 10:44 AM
The_Head's Avatar
This was my first turbo motor, over a year ago now. This setup no longer exsists
so the details are a bit fuzzy.
B18B @ 10 psi
JE 9:1 pistons
Eagle Rods
Crower 62402 Cams with valvetrain
at that time the car had a 2.5" Edelbrock catback exhaust
Old Feb 21, 2003 | 01:58 PM
clendaniel's Avatar
Here's a drag kit on a b18c5 w/ 9:1 JE's, Crowers, and a PowerFC at 15psi.
--Ian
Old Feb 21, 2003 | 02:03 PM
magicwand's Avatar
Default Re: How much HP/TQ has been made with DRAG turbo kit???(Please post Dyno sheets) (falconGSR)
I am building the motor myself.
my setup is
B20VTEC
JE pistons
Eagle rods
GE sleeves
Drag Gen 3
MSD 75 lb injectors
JG Edelbrock intake
JG Edelbrock T/B
Hondata S200
Whalbro 255lph pump
AEM fuel rail
AEM FPR
Skunk cam gears
Old Feb 22, 2003 | 01:46 AM
Trac226's Avatar
Default Re: How much HP/TQ has been made with DRAG turbo kit???(Please post Dyno sheets) (xThexHeadx)
Just wondering if this was the turbo I bought from you
Old Feb 22, 2003 | 05:07 AM
The_Head's Avatar
Default Re: How much HP/TQ has been made with DRAG turbo kit???(Please post Dyno sheets) (Trac226)
Why yes, yes it was. Technically you bought it from my friend. I was just the broker.
Old Feb 23, 2003 | 09:45 AM
magicwand's Avatar
thanks...anybody else?
Old Feb 23, 2003 | 11:25 AM
VaporTrail's Avatar
New User
the drag manifold is shitty for high boost/high power applications. Do a search for "boost creep" on this forum, I think you'll find the common denominator is the drag manifold and it's crap wastegate placement.
Old Feb 25, 2003 | 03:08 PM
magicwand's Avatar
Default Re: How much HP/TQ has been made with DRAG turbo kit???(Please post Dyno sheets) (VaporTrail)
Vaportrail,
I will most likely be bringing this to you for hondata tuning. What do you recommend for the best manifold and wastegate. It is a street car with A/C and stock fans but i could get other fans if need be.I am trying to put down 400+ hp reliably at up to 20 psi.Is the drag i/c and piping able to handle this? Look at my setup above. Do you have any other suggestions?Thanks
Old Feb 26, 2003 | 01:27 PM
magicwand's Avatar
up
bdavis
Apr 10, 2015 08:24 PM
94DB7integra
Apr 4, 2012 10:07 PM
96civic cr-v
Nov 12, 2008 09:43 AM
Tad
Feb 22, 2004 06:51 PM
1stealthls
Mar 31, 2002 07:21 AM
