converting a y8 intake manifold from automatic to work on 5-speed
Old Feb 19, 2003 | 04:47 AM
civicmatt's Avatar
Default converting a y8 intake manifold from automatic to work on 5-speed
What do I need to do to make a y8 intake manifold from an automatic work on a manual transmission car? It's a 98 going onto a 95 dx motor build up. thanks.
Old Feb 19, 2003 | 08:09 AM
civicmatt's Avatar
Default Re: converting a y8 intake manifold from automatic to work on 5-speed (civicmatt)
will it work without any conversion?
Old Feb 19, 2003 | 08:13 AM
Finest's Avatar
I don't think there's any difference between an "automatic" and manual Y8. The motors are the same, only the tranny is different. (Unless I'm missing something here?)
Old Feb 19, 2003 | 08:14 AM
kommon_sense's Avatar
Default Re: converting a y8 intake manifold from automatic to work on 5-speed (98CTRCoupe)
what about the iacv? or is that located on the throttle body?
Old Feb 19, 2003 | 09:03 AM
teal_dx's Avatar
I put a 99 Y8 from 5 sp on my 92 D15b7 which is automatic. I didnt do any converting but I did have to buy a IAC valve from a Y8. it ran a little smoother then
Just plan ahead- 99& 00 Y8 inake manifolds have cold start assist. it is an extra step you have to go through and plug the 4 small flange holes if you are not mounting it to a 99 or 00 Y8 head.
Old Feb 19, 2003 | 12:04 PM
civicmatt's Avatar
Default Re: converting a y8 intake manifold from automatic to work on 5-speed (teal_dx)
thanks for all the replies
Old Feb 19, 2003 | 12:17 PM
tommyboy's Avatar
Go here----------> http://www.makuragi.s5.com/civic_99/Y8maniswap/
termite1r
10
Sep 2, 2013 10:29 AM
SilverDEj6
Jan 30, 2009 03:56 PM
spoontunedek9
Feb 21, 2005 07:12 AM
92civic_eg
Aug 18, 2004 06:24 PM
Dlpz87
May 27, 2004 04:05 PM
