B20 head gasket good for 85mm pistons?
Old Feb 19, 2003 | 12:24 AM
GapxGuy's Avatar
Sushi Buffet Champion
Default B20 head gasket good for 85mm pistons?
Can I use an OEM B20 gasket if I'm using 85mm pistons? Will this be safe?
Old Feb 19, 2003 | 08:32 PM
GapxGuy's Avatar
Default Re: B20 head gasket good for 85mm pistons? (GapxGuy)
Or should I get it stamped-cut to 85mm? Anyone?
Old Feb 19, 2003 | 09:50 PM
10K2HVN's Avatar
i would like to know as well...but doesnt sound good to have that little bit of gasket hanging over the cumbustion chamber...might contribute to......geesh!!! i have a slight fever right now and i cant think!! ..OMG i just had it in my head tooo! ....dentonation (sp)!!! haha i got it!!!!
Old Feb 19, 2003 | 09:56 PM
sgT's Avatar
sgT
Default Re: B20 head gasket good for 85mm pistons? (10K2HVN)
stockl gasket works perfectly fine.
Old Feb 19, 2003 | 10:54 PM
GapxGuy's Avatar
Default Re: B20 head gasket good for 85mm pistons? (sgT)
Ok, thanks sgt.
Old Feb 20, 2003 | 01:23 PM
joe_bocc's Avatar
Even though the bore of the B20 is 84mm?
Old Mar 7, 2003 | 11:19 PM
VitaminB20's Avatar
From: Where the grass is green and the girls are pretty.
Can someone else confirm this? I would also like to know. If this isn't true, where do I find a head gasket that will support 85mm pistons?
Old Mar 7, 2003 | 11:58 PM
TimoneX's Avatar
New User
Default Re: B20 head gasket good for 85mm pistons? (VitaminB20)
A stock head gasket will work fine. I took mine out the first time w/ a dremel...2nd time I didn't bother. It made no difference.
7500rpm
Jan 9, 2014 08:00 PM
BigDare23
Aug 11, 2009 05:22 AM
xQB21x
Nov 21, 2006 02:31 AM
GapxGuy
Dec 22, 2002 05:27 PM
Shft@9GSR
Oct 18, 2002 11:01 AM
