D16A6 tranny bolt on D16Z6?
Old Feb 18, 2003 | 09:41 PM
hybrid_eg's Avatar
Default D16A6 tranny bolt on D16Z6?
My brother may be buying my CRX and wanted to know if the D16A6 tranny would bolt on the D16Z6 longblock he plans on getting.. also when getting a clutch does it have to be for D16A6 or can it also be for D16Z6?
Tks for the advice.
[Modified by hybrid_eg, 10:41 PM 2/18/2003]
Old Feb 18, 2003 | 10:11 PM
JCracer723's Avatar
Default Re: D16A6 tranny bolt on D16Z6? (hybrid_eg)
get 89-91 no 88 and yes u can use d16z clutch
[Modified by JCracer723, 7:12 AM 2/19/2003]
Old Feb 19, 2003 | 04:51 AM
serious's Avatar
Default Re: D16A6 tranny bolt on D16Z6? (JCracer723)
the d16z6 will work with 88-91 si trannies.
if you use an 89-91 tranny, use the d16z6 flywheel, clutch, pressure plate, and the d16a6 release bearing.
if you use an 88 tranny, you need to use the d16a6 flywheel, clutch, pressure plate and release bearing. is is because the 88 use 21 splines vs. the 89-91 20 splines. the 89-91 will allow you to use a larger diameter clutch .
Old Feb 19, 2003 | 08:04 AM
JCracer723's Avatar
Default Re: D16A6 tranny bolt on D16Z6? (serious)
grrrrrr4me
Mar 18, 2005 01:46 PM
I Gotta Question
Jan 2, 2004 03:35 PM
SOcalistreetracer
Jul 10, 2002 12:10 PM
