Weight difference between the stock crank pulley and a JDM R one?
Old Feb 18, 2003 | 08:20 PM
black2001gsr's Avatar
Default ****Anyone know the weight difference between the stock crank pulley and a JDM type R one?
****Anyone know the weight difference between the stock crank pulley and a JDM type R one? I know the JDM type R one is about 6-7 lbs.
Thanks
Old Feb 18, 2003 | 09:37 PM
SurferX's Avatar
Default Re: ****Anyone know the weight difference between the stock crank pulley and a JDM type R one? (blac
There's a difference between the USDM and JDM crank pulley?
Old Feb 18, 2003 | 09:40 PM
Reid's Avatar
Global Moderator
No, there's not.
Old Feb 18, 2003 | 09:42 PM
SurferX's Avatar
More unneeded JDM hype
Old Feb 18, 2003 | 09:46 PM
Reid's Avatar
Global Moderator
The CTR N1 crank pulley that only uses the alternator belt is a worthy buy.
Old Feb 18, 2003 | 10:52 PM
J_Edwards's Avatar
Most definitely. Removing unneeded belt surfaces = reduction in rotating mass.
Note for n00bs: the CTR N1 crank pulley can't be used if you have A/C or power steering...so put away your flame suit and don't bother asking.
Old Feb 19, 2003 | 08:46 AM
sgT's Avatar
sgT
Correction: AC and PS cannot be used with the pulley. Not the other way around.
Old Feb 19, 2003 | 12:00 PM
Hooch'n's Avatar
the stock crank pulley with PS and AC is 10lbs. the N1 is only 2lbs.
Andy: Who just got one!
Old Feb 19, 2003 | 04:56 PM
Tommy_Gunns's Avatar
I bet the UR race one weighs even less
Old Feb 19, 2003 | 05:06 PM
ill phil's Avatar
Is the CTR N1 pulley a special order Honda part, or standard on all B16b's?
Old Feb 19, 2003 | 05:13 PM
Nameless RB26's Avatar
I like my power steering..
Old Feb 19, 2003 | 08:55 PM
MugenizedR's Avatar
If a stock pulley weighs 10lbs, then the JDM type R one is about 4 lbs lighter.
[Modified by MugenizedR, 9:58 PM 2/19/2003]
94IntegraLs04
Mar 9, 2006 02:37 AM
IGotNoSwap
21
Sep 27, 2005 08:17 PM
rolow
Jan 20, 2005 12:48 PM
TurboTeG4
Sep 30, 2003 08:21 AM
