JRSC DC2, 10lb/hondata Question
alright, i have a 2k JRSC GSR. i have the boost upgrade kit @8psi. i have thermal 2.5 catback, kamakazie 4-1, aem ram air intake, jdmhondaparts cam gears, AEM feul rail, and BnM FPR.
I want to upgrade to a 10 psi boost pulley, hondata, larger injectors, and obd1 conversion. should i consider anything else to run 10lbs safely? who makes a 10 lb pulley or do i use the crv crank pulley? which hondata would be the best for my setup and what injectors should i consider? how much should i expect to pay for each?
thanks.
thanks.
i heard endyne makes a 10psi pulley upgrade OBD1 p28 150 adapter harness 250 rc40cc injectors 383 hondata stage 2b 690 obd1 IAT sensor 40 knock sensor upgrade(p30ECU) 200 hondata intake manifold gasket, water injection system 399 your good to go...thats what im gonna do fully built head block n tranny w/ a 50 shot direct port system from NX
with the amount of heat that you'll be producing it might be wise to insure your setup with the J&S safeguard to guarantee no detonation. other than that, hondata is definately the way to go from what i hear, at least for higher levels of boost like what you're talking about.
hondata 2b, DSM 450's, and a GOOD tuner. That last part is the most important, without that you may as well throw BB's in your intake and call it a day. Keep in mind you really are pushing a JRSC to its max.
Misc other things that go with the main parts...
Resister Box (junkyard)
ODB1 IAT sensor (junkyard)
ODB1 ECU
Injector Clips (junkyard)
ODB2 to ODB1 harness
Good luck
ODB1 ECU
Good luck
Pfieff
Dec 3, 2003 06:04 PM
