Fuel pump question for 89 crx
Old Feb 18, 2003 | 06:07 PM
CrazyKoreanCrx's Avatar
Default Fuel pump question for 89 crx
I need to know if anyone knows about where or what do i used to upgrade a fuel pump in a 89 crx hf? The swap is a b16a2 motor.So what do i do to do this then.-------Thank you everybody
Old Feb 18, 2003 | 07:17 PM
raene's Avatar
Default Re: Fuel pump question for 89 crx (CrazyKoreanCrx)
I used a Holley 190lph pump for an Integra. You have to custom-wire the wiring harness a bit - just make sure to get positive to positive - and rig the pump so that it sits in the pump mount correctly, but otherwise it works great.
If you want more details go to my website in the 'How To' section
Old Feb 19, 2003 | 04:16 AM
jcda6's Avatar
a easy upgrade would be to grab a fuel pump from the 2nd gen Integras 90-93. Stock fuel delivery is I believe aroudn 190 lph. Or you can buy a Walboro 255lph which is more than sufficient for even mildly tuned Hondas.
-Jeff C.
Old Feb 19, 2003 | 08:04 AM
Jeff C's Avatar
Get your Walbro (either 190 or 255) from autoperformanceengineering.com. He sells them as a kit and there is no wiring that is needed...just plug and play.
[Modified by Jeff C, 12:05 PM 2/19/2003]
Splock
Jul 30, 2017 08:57 AM
Cute EK
Jan 6, 2006 09:06 PM
JRex89
Mar 16, 2004 02:08 PM
Leperchon
Jan 8, 2004 06:28 PM
