Do I need bigger injectors with new Cams?
I have a hatch with a GSR. Going with Skunk2 stage 2 cams and springs and Skunk2 IM. Already have header. Do I need larger injectors for this or can the stock ones flow enough to keep up?
Your injectors will be fine, I would only Get larger ones if you had High compression also!
BTW.. For your aplication I would maybe look more into Skunk Stage 1 cams, I made 196whp with those!
Good Luck, Eric
Good Luck, Eric
honda data
Apr 13, 2013 11:51 AM
hbboostman
Dec 17, 2007 03:57 PM
