Amount of time to change lower control arm?
Old Feb 18, 2003 | 02:21 PM
bad93ex's Avatar
Default Amount of time to change lower control arm?
How long does it take to change a lower control arm if you have all the stuff?
What is all the stuff you need to do it? It was icy out and I hit a curb. Sucks *** wearing my tires down kinda bad.
Old Feb 18, 2003 | 03:46 PM
poison's Avatar
Default Re: Amount of time to change lower control arm? (bad93ex)
With all of the tools, it usually takes an hour at most to replace both of them.
all you do is unbolt bolts and remove and replace, that's about it.
Old Feb 18, 2003 | 04:05 PM
JV's Avatar
JV
Who?
Default Re: Amount of time to change lower control arm? (poison)
If it's the rear LCA's just watch out for the bolts that hold the shock onto the LCA. Those little bastards like to freeze up inside the bushings.
Make sure you spray everything with wd-40 or it's equivalent. Let it soak in for a couple hours too...
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
If the bolts aren't too stubborn I could probably replace both LCA's in 15-20 minutes.
Old Feb 18, 2003 | 05:41 PM
EKhatch's Avatar
Doesn't really take too much time at all. If it is the front LCA's then you will need a pickle fork to get the ball joints loose.
Old Feb 18, 2003 | 05:45 PM
euclid's Avatar
Default Re: Amount of time to change lower control arm? (EKhatch)
i learned that one the hard way
Old Feb 18, 2003 | 06:02 PM
poison's Avatar
all I have to say is that is one pain in my *** with that lol.
Draven8795
Aug 27, 2010 01:12 PM
eg2_RE
Apr 1, 2004 05:56 PM
bad93ex
Mar 12, 2003 09:29 AM
Jape
Nov 13, 2002 04:35 PM
stumpyf4
Aug 29, 2002 05:29 PM
