Sway bar sizes in RSX type-S and Civic SI (EP3)
My friend has a EP3 and was wondering if the type-s swaybars were any larger or smaller than his. He is looking at buying a set and whether or not it would be benificial. Thanks! Rick
the Type S has a 23mm hollow sway in front and a 19mm solid sway in the back...it's the same with the base model RSX...don't know about the EP3 though...hope that helps...late
I believe the EP has a 13mm rear bar, it is much smaller than the RSX-S bar. I have an EP and have swapped in the RSX-S bar and can feel the difference, - the car is much tighter in corners and understeers less, very much more neutral. Highly worth the upgrade I believe!
Type-Spaz
Jun 26, 2011 01:16 PM
Shaynepolevault
Jan 7, 2010 11:06 PM
square_1
11
Feb 3, 2009 05:21 AM
crazydjr26
Oct 13, 2004 12:22 PM
