Crank Polishing what is it and whats the benifit?
Old Feb 18, 2003 | 06:36 AM
ForeignConcepts's Avatar
Default Crank Polishing what is it and whats the benifit?
could anyone shed some light on both this and knifing the crank. and if you do knife the crank how does it effect balancing of the internals?
Old Feb 18, 2003 | 06:56 AM
rastropovitch
Guest
Posts: n/a
Default Re: Crank Polishing what is it and whats the benifit? (ForeignConcepts)
Knife Edging will help with windage... and the material is SUPPOSED to be taken off with balance in mind. You still have to high speed balance the entire rotating assembly. Polishing removes inperfections on the surface where cracks or stress fractures can start.
Schu
Old Feb 18, 2003 | 07:10 AM
Default Re: Crank Polishing what is it and whats the benifit? (MSchu)
that was probably the most simple and direct answer ever. thank you for taking the time ....
Old Feb 18, 2003 | 08:37 AM
rastropovitch
Guest
Posts: n/a
Thanks to you
Peace
Schu
95dcsleeper
Sep 5, 2005 06:48 PM
MauiCivic
Feb 19, 2003 08:55 PM
