how to fit aftermarket speakers
Old Feb 17, 2003 | 11:38 PM
Loveless's Avatar
Default how to fit aftermarket speakers
I have a 4 door so it's 6 and half inch for me.
I have infinity kappa speakers and they're about 2 and a quarter deep into the door panel. It's definitively not going to fit into the stock "bowl". I used to have these speakers on my accord and I "cut" the bowl to make them fit. I don't want to do that any more, any suggestions? A few searches on speakers have been done with little useful information.
Old Feb 17, 2003 | 11:49 PM
b18bfreak's Avatar
Default Re: how to fit aftermarket speakers (Loveless)
cutting is you only option. Spacers will make the speakers hit the inner door panel. Whats wrong with cutting the bowl?
Old Feb 18, 2003 | 10:08 AM
Rtzx9r's Avatar
GDD 1%
Default Re: how to fit aftermarket speakers (b18bfreak)
I did this on my 2-dr and removed the bowls in the front and made wood "donuts" that spaced the speakers outward a bit.
The rears I cut the bowls up so the speakers could fit, but being a 4-dr I believe that these are in the trunklid thingy.
Old Feb 18, 2003 | 01:18 PM
Volcom's Avatar
Default Re: how to fit aftermarket speakers (Rtzx9r)
I also made wood donuts for my Boston's in the front. Then I drilled four holes through the wood and into the door. Next, I just used four sheet metal screw and went through the speakers, wood and into the door. They're on there tight.
Old Feb 18, 2003 | 01:39 PM
94civicx's Avatar
New User
Default Re: how to fit aftermarket speakers (Volcom)
had to cut the bowls for my 6.5" fosgates. only way they will fit
Old Feb 18, 2003 | 08:36 PM
TimoneX's Avatar
New User
Default Re: how to fit aftermarket speakers (94civicx)
I removed the bowls and made wooden donuts for my CD Tech sats. Best way to get a decent sized bass driver into the door.
Old Feb 19, 2003 | 08:41 PM
Loveless's Avatar
can I see some photos of these donuts?
Old Feb 19, 2003 | 09:57 PM
Volcom's Avatar
basically a piece of wood that I cut out using a jig saw. It doens't have to be perfectly round, just thick enough for the speaker to sit on and not make any contact behind it.
Old Feb 19, 2003 | 11:04 PM
Loveless's Avatar
ok I am fucked, I don't have a jig saw and I Don't know anyone with it.
[Modified by Loveless, 12:04 AM 2/20/2003]
Old Feb 19, 2003 | 11:14 PM
TimoneX's Avatar
New User
So buy a jigsaw, rent a jigsaw, buy a coping saw, use a serrated plastic knife, this is not rocket science.
Old Feb 20, 2003 | 05:23 AM
bri's Avatar
bri
Default Re: how to fit aftermarket speakers (TimoneX)
You guys who removed the bowls, aren't there problems with the speaker cone getting wet? I didn't even take the bowl out and one speaker was wrecked after a couple months from getting all wet. i don't there's any kind of seal in the door to keep water out
Old Feb 20, 2003 | 05:49 AM
2k1_ITR_0736's Avatar
Default Re: how to fit aftermarket speakers (bri)
i usually cut the bowls.
< MECP certified installer.
ocasionally ill make a plate out of ABS plastic. depending on the door panel, the new speakers wont fit with wood rings.
Old Feb 20, 2003 | 09:38 AM
Loveless's Avatar
yes but I am poor though I still have the speakers I believe they are infiniti kappa 63.3i
Derrick Berry
Mar 16, 2020 03:22 AM
Masho
Honda Civic (2001 - 2005)
Jan 8, 2012 01:58 PM
PDXHatchback
Mar 18, 2007 05:28 PM
Unjockable
Audio / Security / Video
12
Dec 15, 2003 10:22 AM
onyx00
Sep 6, 2001 11:32 PM
