welding hks bov?
i need to weld my hks BOV flange to my charge pipe...and my charge pipe is Steel. and i believe the hks bov flange is aluminum....how can i weld it and wat kindda welding do i need? Tig Weld? Sorry i don't know too much about welding...thanks
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
If it's Steel, then you need a steel flange to weld your bov. If your pipe is aluminum, then you need a aluminum flange.
interesting.. you have a aluminum flange, but you need a steel one cause your pipe is Steel.
I NEED a aluminum flange... cuase my Pipe is aluminum, but I have a Steel flange.
Looks like we both have the same problem. I've already ordered a aluminum flange though.
boostincoupe
Aug 3, 2006 09:49 PM
adhana2
Jun 2, 2003 02:16 PM
