how hot do turbo manifolds get?
Old Feb 17, 2003 | 07:55 PM
ridnmyhonda's Avatar
Default how hot do turbo manifolds get?
i have a dragIII manifold how hot does that baby get....?? thanks
Old Feb 17, 2003 | 07:59 PM
Hondatec38's Avatar
Default Re: how hot do turbo manifolds get? (ridnmyhonda)
Hot..hehe. Seriously it kind of depends on how hard you drive. I don't know any numbers though. Driving habits can affect the temperature to my knowledge.
Old Feb 17, 2003 | 08:01 PM
keebler65's Avatar
Default Re: how hot do turbo manifolds get? (Hondatec38)
search for "EGT" posts to give you some idea depending on setups
Old Feb 17, 2003 | 08:17 PM
Andrew 825SM's Avatar
Default Re: how hot do turbo manifolds get? (keebler65)
Dude... I put my hand on one and all I can say was "It was damn hot!"
Old Feb 17, 2003 | 08:28 PM
SpdFrk's Avatar
put your hand on one and find out..j/k.
They get really hot. Even if you don't drive it hard they still get to a point where they will burn you really bad.
[Modified by SpdFrk, 5:28 AM 2/18/2003]
Old Feb 17, 2003 | 08:48 PM
Default Re: how hot do turbo manifolds get? (SpdFrk)
thanks guys...lol i know they get hot does anybody have any idea on actually temperature...above 300 or below 300?? thanks
Old Feb 17, 2003 | 08:52 PM
tegasaurus's Avatar
about 4 times that hot
Old Feb 17, 2003 | 09:01 PM
Anubyss's Avatar
Default Re: how hot do turbo manifolds get? (tegasaurus)
I've seen my egt reading go to 1600 degrees F. So I would imagine the manifold to be about that hot as well.
Old Feb 17, 2003 | 09:07 PM
b16ahybrid's Avatar
Do you plan to do some cooking or something?
Old Feb 17, 2003 | 09:11 PM
PrecisionH23a's Avatar
Default Re: how hot do turbo manifolds get? (b16ahybrid)
my egt's are usually 800deg C
Old Feb 17, 2003 | 09:56 PM
XES's Avatar
XES
Default Re: how hot do turbo manifolds get? (GudeH23a)
I can easily max out one of those infra-red temperature guns...when I point it at the manifold after heavy driving...
Old Feb 17, 2003 | 10:06 PM
T-sohctec's Avatar
I have to admit I'm alittle bit concerned as to why you need to know this?!?!
ohh and if you don't know yes it will be much more than 300deg.
please tell me this has nothing to do with JB weld or the like
Old Feb 17, 2003 | 10:08 PM
CzanSOHC's Avatar
Default Re: how hot do turbo manifolds get? (T-sohctec)
Just a tad hotter then that
Old Feb 17, 2003 | 10:14 PM
rOby's Avatar
Default Re: how hot do turbo manifolds get? (CzanSOHC)
hot enuff that u dont wanna touch it,
Old Feb 17, 2003 | 11:04 PM
Snafu-Si's Avatar
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
Default Re: how hot do turbo manifolds get? (rOby)
Try sticking your tongue on it after some hard driving...
Let me know how it feels okay?
I'm kidding.. don't do that.. it would melt your tongue off.
Old Feb 17, 2003 | 11:36 PM
Daniel's Avatar
Default Re: how hot do turbo manifolds get? (Snafu-Si)
nah, probably just start blistering in about a minute or so. my dumbass friend put his finger close to my mani to try and burn his knuckle hairs off. needless to say, he got burned.
Old Feb 17, 2003 | 11:39 PM
Mista Bone's Avatar
D Tranny Guru
Due to physics and "Leidenfrost effect" I'd stick my tongue on any turbo manifold.
I've already dipped my hand into molten lead to prove it.
I've also held Dry Ice in my mouth for over 45 minutes.
At or above the Leidenfrost point, however, the bottom layer of the droplet vaporises almost immediately on contact, effectively creating a cushion of vapour that repels the rest of the droplet from the surface. The droplet does not make contact with the surface, and thus no heat can be transferred directly from the surface.
At such high temperatures, one might expect that the vapour layer would quickly transfer enough heat to the rest of the droplet to vaporise it. Water vapour, however, is a very poor conductor of heat at these temperatures. Hence, the vapour layer actually acts as an insulator.
Old Feb 18, 2003 | 05:57 AM
SoulSurfer's Avatar
Default Re: how hot do turbo manifolds get? (Mista Bone)
I'm going lava swimming tomorrow, wanna come?
Old Feb 18, 2003 | 06:36 AM
TurbothisLS's Avatar
Default Re: how hot do turbo manifolds get? (LSDelSol)
lol
Old Feb 18, 2003 | 06:50 AM
johnisenglish's Avatar
Jeral Walker!!!!
(I really hope that SOMEONE gets that...)
Old Feb 18, 2003 | 07:16 AM
genop's Avatar
Default Re: how hot do turbo manifolds get? (johnisenglish)
I'll bet you fifty bucks that if you stick your tounge to the turbo mani your tounge would get burnt to hell. Maybe if you just did it really quick you wouldnt be burned really bad..... Hey if you want to try it, goahead. Just make sure to video tape it so I can laugh my *** off!!
Old Feb 18, 2003 | 09:32 AM
underpressure02's Avatar
I sprayed my manifold with my ceramic header paint that I use on all my cars. The first day of driving it around I cooked most the paint off. That is supposed to be good up to 1500. Hope that helps.
Old Feb 18, 2003 | 09:50 AM
Daniel's Avatar
Jeral Walker!!!!
Google says he's a physics instructor at Cleveland State University. same dude you're talking about?
and i remember the concept Mista Bone is talking about from way back when in high school physics. i still wouldn't put any part of my body near my exhaust mani, though.
Old Feb 18, 2003 | 11:29 AM
SOHC_power's Avatar
Default Re: how hot do turbo manifolds get? (Daniel)
put your weener on it..... hehe
Old Feb 18, 2003 | 12:34 PM
Mista Bone's Avatar
D Tranny Guru
Jeral Walker!!!!
EXACTLY!
