Problem: slight hesitation just off idle
Old Feb 17, 2003 | 05:10 PM
Sam5's Avatar
Default Problem: slight hesitation just off idle
'98 Accord LX 4 cyl AT 50K miles
When I go to hit the gas from a stoplight and I apply just a little pressure to the pedal, the engine will sometime act like it wants to quit. This only happens just off idle. Once the revs pick up, it's just fine. If you step on the pedal a decent amount, it's not even noticable. Is this normal?
Just tuned it up: oil&filter, ATF change, new plugs, new air filter, new PCV valve, just ran some Techron fuel injection cleaner.
Old Feb 17, 2003 | 06:47 PM
Bantam's Avatar
2nd Coolest Person in DFW
Default Re: Problem: slight hesitation just off idle (Sam5)
You didn't mention plug wires, did you get those? because I had a friend with a Maxima that acted like that b/c of wires.
Old Feb 18, 2003 | 01:24 AM
Stripped Honda's Avatar
99-0104
Default Re: Problem: slight hesitation just off idle (tharptroy)
i agree to check the wires but change the spark plugs and change the fuel filter ... check the cap and rotor to see if they are bad that should solve your problem
Old Feb 18, 2003 | 08:06 AM
Sam5's Avatar
Default Re: Problem: slight hesitation just off idle (Stripped Honda)
How do you change the fuel filter? Thought it was in the fuel tank?
I will look into getting new wires, rotor, and cap.
Old Feb 18, 2003 | 01:18 PM
Chiovnidca's Avatar
You don't need to unless it's causeing a problem. (It probably isn't.)
Team_Coast978
Jan 3, 2013 02:43 PM
hondachris1994
11
Mar 24, 2008 01:02 PM
myRice
Nov 20, 2005 11:45 AM
BigZ88
Dec 3, 2003 05:50 AM
Hybrid Boy
Sep 1, 2002 03:16 PM
