What Throttle Body to use with Skunk2 IM??
Old Feb 17, 2003 | 04:30 PM
B00ST2nR's Avatar
Default What Throttle Body to use with Skunk2 IM??
I got my Skunk2 Intake Manifold and an ITR AEM CAI for my car. Now... should I just use my stock Throttle Body (60mm), or should I go bigger? I heard its not good if its TOO big.
What Throttle Body should I use if I should replace it? What size?
Old Feb 17, 2003 | 04:33 PM
Big Teggie's Avatar
Default Re: What Throttle Body to use with Skunk2 IM?? (Skunk2nR)
Just get your stock one overbored. I heard 64-66 is all you will ever need on an NA setup. I have a bored out B16 one sitting next to me. Its 64mm. Talk to "Spaceballs the lunchbox". He bored mine, I have yet to try it out.
Old Feb 17, 2003 | 04:36 PM
StinkyTofu's Avatar
Just use your stock throttle body for now. It should suffice. I would recommend getting a non-gsr throttle rotor so you can mount your throttle cable properly, allowing you to use your strut bar.
Old Feb 17, 2003 | 05:00 PM
GQ 05YellowEVO8's Avatar
Default Re: What Throttle Body to use with Skunk2 IM?? (StinkyTofu)
I sent out my 95 GSR T-body to AEM for porting and thats what I use now on my Skunk 2 Manifold.
Old Feb 17, 2003 | 05:40 PM
RacerZook's Avatar
Default Re: What Throttle Body to use with Skunk2 IM?? (13 Sec GSR)
Keep the stock one on untill you tune it. If the MAP dips below 16 psi or 1 bar ( I think that's right, I'll have to get back to you on specific numbers) then you would need a larger TB. Otherwise it shouldn't be needed.
Old Feb 17, 2003 | 05:52 PM
B00ST2nR's Avatar
Default Re: What Throttle Body to use with Skunk2 IM?? (RacerZook)
Yea. I know alot of people who run on Stock GS-R TB with their Skunk2 Intake Manifold...
Old Feb 17, 2003 | 06:13 PM
neo1z's Avatar
I would be interested in seeing some dyno numbers from a TB -- my bud dan got a 64mm TB with his ITR IM (on a b17), and said the difference was fairly negligable (he is also ITR cammed). Anyway...I don't know if I'll be doing a TB before I get it tuned. I guess he isn't running as aggressive cams as our Stage 1's Skunk2nr...but if you get a 64mm or 62mm TB, let me know how it goes. Im tuning in late march, so I'd wanna get it done by then.
Old Feb 17, 2003 | 06:30 PM
B00ST2nR's Avatar
Default Re: What Throttle Body to use with Skunk2 IM?? (neo1z)
For sure.
I'm gonna tune my car after I get some more stuff into it. I just got the Skunk2 Intake Manifold and ITR AEM CAI. So now I need a JDM 4-1 Header, 2.5" inch Cat., Skunk2 Valvesprings and Retainers, and a Skunk2 ECU.
I'll be tuning it after all that goes in, and I expect my numbers to jump...
Old Feb 17, 2003 | 07:26 PM
stupidfast's Avatar
I have a 64mm to match the intake manifold, but it made no more power on the dyno..Waste of money..
Old Feb 17, 2003 | 08:07 PM
B00ST2nR's Avatar
Default Re: What Throttle Body to use with Skunk2 IM?? (stupidfast)
Aite cool. Thanks for the heads up. I'll be stickin with the stock GS-R TB then.
Mccormick009
Sep 30, 2014 02:01 PM
SiR-T
Nov 19, 2007 08:23 PM
mortificationrock
17
Nov 13, 2007 06:49 AM
phantom_sol
Feb 19, 2004 11:49 PM
BLK99VTECR
Feb 15, 2004 02:37 AM
