apexi n1 for 99 gsr fit my itr?
Old Feb 17, 2003 | 02:17 PM
paRRRker's Avatar
Default apexi n1 for 99 gsr fit my itr?
like topic says, will an apexi n1 full catback exhaust for 99 integra gsr fit my 98 itr?
thanks
Old Feb 17, 2003 | 02:21 PM
StinkyTofu's Avatar
Default Re: apexi n1 for 99 gsr fit my itr? (Hype-aaaRRRR)
thanks
If you take the '99 GSR cat with you, it will work.
Old Feb 17, 2003 | 02:34 PM
paRRRker's Avatar
Default Re: apexi n1 for 99 gsr fit my itr? (StinkyTofu)
i know the rear lower control arms are different and didnt know if there would be a clearance issue or anything like that. im planning on purchasing a used n1 for the gsr to install on my itr, then also installing my dc sports jdm 4-1 header, up to a carsound cat maybe then too the n1. the only other question i have now is what kind of cat to get and what size. i know i need the collector size to be 2.5" for the jdm header style specs, but im not sure what size to get on the other end of the cat to bolt directly up to the apexi n1 without modification. any help will be greatly appreciated.
Old Feb 17, 2003 | 02:50 PM
98cwitr's Avatar
any exhaust (i take that back...almost any) that fits an LS will fit a R...not a GSR w/o the cat
Old Feb 17, 2003 | 02:52 PM
Hugh Bowie's Avatar
Default Re: apexi n1 for 99 gsr fit my itr? (98cwitr)
apex n1 is great dont get me wrong...
but i have rsr (the old one)
and i will never get a dif one
before you buy listen to a couple dif ones
Old Feb 17, 2003 | 03:04 PM
paRRRker's Avatar
Default Re: apexi n1 for 99 gsr fit my itr? (Hugh Bowie)
would you ming posting some of your sound clips then to make my decision a little easier. thanks
Old Feb 17, 2003 | 03:15 PM
00MRSi's Avatar
Check out the new Skunk2/RSR Invidia N1 catback. Very good quality, and sounds good. Available in fully polished stainless steel. I have the APEXi N1 catback. It's nice, but damn canister is HUGE!! Good luck.
Old Feb 17, 2003 | 03:43 PM
paRRRker's Avatar
Default Re: apexi n1 for 99 gsr fit my itr? (00MRSi)
thanks man
Old Feb 17, 2003 | 04:09 PM
StinkyTofu's Avatar
I have a '94-'99 GSR carsound cat for a jdm 4-1 header. Its brand new and if you buy it, you can use your GSR n1 cat-back.
Side note, All LS, '00-'01 , TYPE R cat-backs are the same length.
Old Feb 17, 2003 | 05:23 PM
Dee Cee 2 R's Avatar
i have an n1 on my R.
The LS and R are the same part number.
Old Feb 17, 2003 | 07:09 PM
paRRRker's Avatar
so what is the difference between your gsr carsound cat that bolts up to the dc sports jdm 4-1 header at 2.5" at the collector and also bolts directly up to an apexi n1 at like 2.25" on the other side of the cat, than an itr carsound cat that does this?
thanks, btw, how much are you asking for your cat?
Old Feb 17, 2003 | 07:12 PM
MugenizedR's Avatar
It will work, you just need to shorten the b-pipe by about 5 inches (cat end)
Old Feb 17, 2003 | 07:19 PM
StinkyTofu's Avatar
It was purchased brand new from IPS racing. Thought i needed a new cat cause there was a rattle. Found out it was my header bracket, so i didn't need to replace the cat. Still brand new and has the warranty card. I'm asking for 150 shipped. It will bolt up to your system if you get a DC JDM 4-1 and a '94-'99 GSR apexi n1 catback.
Its 2.5 inches in/out. Even though the apexi n1 is 60mm (~2.36 inches), it will still bolt up fine. There is no difference between this GSR carsound and ITR carsound except one is a tad bit longer than the other to accomodate for different b-pipe sizes.
I have an '01 GSR which has the same b-pipe length as the type R. I have a '94-'99 apexi n1 cat-back with a '94-'99 carsound cat plus a jdm 4-1 header. Everything works great and fits perfect.
Old Feb 17, 2003 | 07:24 PM
paRRRker's Avatar
just found out that it is not a 99 i dont think, he has it on his 2000 gsr so i assume that the apexi n1 is for a 2000 gsr. would this make a difference? thanks
Old Feb 17, 2003 | 07:27 PM
StinkyTofu's Avatar
Yeah, if the n1 is a 2000 gsr model, it will bolt up to your stock cat. But you're gonna need to replace that cat with an ITR carsound cat if you want to run it with the JDM DC header. Good luck.
paRRRker's Avatar
so if it is an 2000 gsr model exhaust, then i need to get the itr carsound cat that is 2.5" all the way thru, and then i can bolt it up to the dc jdm 4-1 and the apexi n1 and not have any exhaust leaks and not have to do any modifications?
thanks again man
[Modified by Hype-aaaRRRR, 8:33 PM 2/17/2003]
Old Feb 17, 2003 | 07:38 PM
StinkyTofu's Avatar
Yeup that is correct.
'00-'01 GSR/All year LS/All year Type R Exhaust systems->> All have the same part number.
To not have any exhaust leaks, you need to make sure you have all your gaskets. Everything will bolt up fine without any modifications.
Old Feb 17, 2003 | 07:41 PM
paRRRker's Avatar
would those gaskets that i need come with the apexi n1 exhaust, or would i use the ones of my stock exhaust system? thanks
Old Feb 18, 2003 | 12:41 AM
00MRSi's Avatar
If I remember correctly, APEXi supplies the exhaust gaskets. Just remember to get the 2.5" donut gasket for your JDM header..
Old Feb 18, 2003 | 04:52 AM
paRRRker's Avatar
the 2.5" exhaust donut is the part number for the s2000 right? cause i already ordered that part.
thanks
Mikey661
Oct 7, 2010 07:16 AM
hYpE-R-29
Mar 28, 2003 08:41 AM
DD_JonnyLee
Jan 17, 2003 12:21 AM
migs
Jun 25, 2002 01:28 PM
