SKUNK2 coil over off the shelf rates?
Searched, but to no avail. Does anyone know the off the shelf rates on the SKUNK2 coil overs for the 88-00 civic/crx/delsol? Also does anyone if and where you could order a set of SKUNK2 coilovers with there 7"x2.5" 6K front springs and 7"x2.5" 8K rear springs? I know they sell separate springs like ground control does so can you order custom rated SKUNK2's? or does anyone know a place to order just the springs? Thanks.
I believe the Civic kit comes with a 300/400 setup and the Integra one is 400/500. As for the custom stuff, I'd say to call directly to find out. Sorry, I don't know the answer to that.
Well if anyone wants to do me a huge favor and look on one of the front and one of the rear spring I would be much abliged <sp?>.
It would look something like this - "0700.2.50.0--" I need those two dashs filled in. Basically saying the springs are 7" x 2.5" x -- which is the spring rate in kg/mm. Thanks.
The civic kit will say a .080 and a .060 and the Integra kit will say .100 and a .080. I don't quite remember what the number is for my drag launch kit.
Kasper.
Apr 23, 2004 06:02 PM
