Alternator
I was wondering if i need a new alternator, or better grounds in the engine bay. Heres the problem....when i am stopped at a light and i have the brake pedal depressed, then the headlights and console lights dim, and when i let go, they go back to normal power....also, when i have only the accesories on (engine not running) it seems like my car cant produce enough power to roll the windows up or down.....i do have a system, but it only has a 300 watt amp, and one sub, so i dont see it being that...i have already cleaned the ground connections down to the body, so that isnt any paint over them, and i was also wondering if a ground wire kit will help, i already have it, but just need to know where to hook them up....also, would a new alternator take care of any of these problems anyway?? thanks for all the help!
thanks Noe.....do you think an alternator with a higher amp rating would be better too?? i dont want to buy a new one and then have the same problems down the road again.......
