Oil Intercoolers @ Pep Boys???????
Old Feb 17, 2003 | 12:12 PM
greebler's Avatar
Default Oil Intercoolers @ Pep Boys???????
Ok so I saw these intercoolers @ Pep Boys the other day, they are like $40 or somthing, for just hte core. Anyone seen these or have opinions?
Old Feb 18, 2003 | 08:31 AM
civic disobedience's Avatar
Default Re: Oil Intercoolers @ Pep Boys??????? (greebler)
to me this sounds like it's just the cooler core, in order to hook it up you are going to need an adapter that goes on the block where the oil filter screws onto (either a sandwich, or relocator type) its also recomended to use a thermostat so the oil doesn't get over cooled, as well as the lines between all the componets in the system. I pieced together my own kit last year, and between buying all the parts, and many trips back and forth to the store for fittings, and hoses etc. I would have just spent the $$ on a kit, like Greddy makes (would have spent a little more, but having all the componets in one shot would have been worth the extra $$)
also I had to remove the tube the oil filter screws onto and machine about 1/4" off of it cause the adapted didn't mate up to the block correctly... hope this helps...
duh... should have read closer... you even said its just the core...
[Modified by civic disobedience, 12:32 PM 2/18/2003]
Old Feb 18, 2003 | 03:51 PM
greebler's Avatar
Default Re: Oil Intercoolers @ Pep Boys??????? (civic disobedience)
right on, thanks for the info.
TurboEM1
May 5, 2006 07:15 AM
TypeC
Apr 29, 2005 12:33 PM
JDMTurboCivic11
Oct 26, 2004 07:18 AM
