Suggestions on next mod?
Old Feb 17, 2003 | 07:18 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Suggestions on next mod?
My current setup is an AEM CAI, JDM DC header, Skunk II stage one cams, Action Kevlar clutch, and Fidanza flywheel. I have a VAFC on the way soon to be followed by a 2.5" mandrel bent exhaust and FPR. So in terms of engine or acceleration aiding mods where can I go from here? I'm thinking maybe I could use some injectors? Ideas please.
Old Feb 17, 2003 | 07:20 AM
Chris N's Avatar
Default Re: Suggestions on next mod? (ActiveAero)
Weight reduction?
I'd say get rid of the vafc and get something that can extract more power out of your engine. (hondata, powerfc)
Old Feb 17, 2003 | 07:21 AM
migs's Avatar
Default Re: Suggestions on next mod? (Chris N)
Sell 4.40 tranny and get 4.785 tranny. No power extracting from your motor but you can get about 20 butt dyno horsepower out of it.
Old Feb 17, 2003 | 07:47 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Weight reduction?
Well I just bought the VAFC and plan on living with it for a while since I have such a mild setup. I'll get something better when I go 2.0liter.
I really don't feel like pulling my tranny for a FD install either unless I can get some fellow HT members to help out. Pulling a tranny by yourself isn't fun.
Old Feb 17, 2003 | 08:37 AM
Tommy_Gunns's Avatar
You have just about every power upgrade bolt on for the ITR. Maybe some underdrive pulleys?
Old Feb 17, 2003 | 08:49 AM
vtec.dc2's Avatar
replace vafc with hondata, get a better header --> if you plan to stay all motor, you will need these either way.. injectors are more needed for high rpm - so you don' have to raise fuel pressure, maybe 270's or get larger injectors if you do plan to rebuild motor.
may i suggest a snail?
Old Feb 17, 2003 | 09:52 AM
RATEDR's Avatar
Default Re: Suggestions on next mod? (vtec.dc2)
yeah i dont think bigger injectors will be needed with your setup. I'd opt for a better header like Toda or maybe SMSP. Then get a FD as your next mod after that.
Old Feb 17, 2003 | 10:28 AM
Champ R's Avatar
Default Re: Suggestions on next mod? (RATEDR)
JDM or ATS final drive?
Old Feb 17, 2003 | 11:11 AM
Rob Dizzle's Avatar
hondata
and injectors.
then just drive your car more. put the extra money into track days or for gas taking small road trips.
your car is plenty fast, just enjoy it
Old Feb 17, 2003 | 01:33 PM
Bbasso's Avatar
Do you have traction?, You might want to think about it as your power goes up...
Old Feb 17, 2003 | 01:36 PM
Cosworth's Avatar
Default Re: Suggestions on next mod? (Bbasso)
17" Concept neepers. They will help w/ traction.
Check yo, IM.
Old Feb 17, 2003 | 01:38 PM
Hooch'n's Avatar
Default Re: Suggestions on next mod? (Cosworth)
Slicks!
Old Feb 17, 2003 | 01:49 PM
ITR#132's Avatar
Cam gears.
Old Feb 17, 2003 | 02:41 PM
MK Ultra's Avatar
I would suggest hondata and injectors as well. These won't necessarily make much more peak power, but you will be able to tune the motor more precisely, giving you a smoother power curve and a generally better-running motor.
The reason I suggest the injectors is what I witnessed while doing some experimental tuning with a friend. We noticed that a B17A (same size injectors as the B18C) with ITR cams and IM ran the injectors at 100% duty cycle at everything past 7500 rpm. The Motec Lambda meter showed a/f ratios as lean as 16.5:1 + at over 8000 rpm. This was on a very mild motor (still had stock cast iron exhaust manifold) that displaces 100 fewer cc's than a B18C.
Old Feb 17, 2003 | 02:48 PM
Hugh Bowie's Avatar
Default Re: Suggestions on next mod? (MK Ultra)
cam gears for the fpr and those cams yo
or pullies...
theres really not much else that bolts rite on
Old Feb 17, 2003 | 02:49 PM
itr1244's Avatar
All i can think of are..
(as long as you keeping your skunk2 stage 1 cams)
-You could always upgrade your cams more than stage 1+)
-Cam gears
-Fule regulator
-Bigger injector
-Lighter flywheel
-weight redution.
sorry i dont know if it helped at all but that's all i can think of right now.
Oh yeah. i forgot something.
there'zzz Boost for joo too
[Modified by itr1244, 11:50 PM 2/17/2003]
Old Feb 17, 2003 | 02:53 PM
98cwitr's Avatar
Default Re: Suggestions on next mod? (itr1244)
yank those cams out and buy a turbo...just my .02
Old Feb 17, 2003 | 07:22 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Default Re: Suggestions on next mod? (98cwitr)
Well I already have cam gears. Looks like injectors might be on the list. The only other thing I could come up with is a Hondata intake manifold gasket.
Old Feb 17, 2003 | 07:25 PM
Kengs's Avatar
Take the money, drive up to VA and let Sakai work his magic
Old Feb 17, 2003 | 07:28 PM
Black R's Avatar
25 Year Member
Default Re: Suggestions on next mod? (kengs)
ditto.
Go with a good header like toda, smsp, hytech...
ditch the "junk" cams and get spec a's...
97+ prelude (290cc) injectors
ATS final drive you big sissy
SLICKS, y0!
More $.....
Rinsta
Jun 17, 2009 12:32 PM
4doorex
21
Nov 22, 2004 06:19 AM
del_sol
Mar 26, 2003 07:04 AM
blacklude
Nov 5, 2002 04:53 PM
itr1236
Oct 18, 2001 01:30 PM
