2000 LX 4cyl Check Engine Light
Old Feb 17, 2003 | 04:48 AM
muskrat's Avatar
Default 2000 LX 4cyl Check Engine Light
Yes, I searched recent and archived topics and loooked at each one, not my situation.
My wife has a 2000 Accord LX, 4cyl 5 speed. The car has 81,xxx miles on it. I changed the oil in it about a week ago. She called me this morning after she got to work and told me that on the way in her check engine light came on. Anything I should check myself before taking it to a shop? The weather this morning was wet cold and icy.
Old Feb 17, 2003 | 07:34 AM
muskrat's Avatar
Default Re: 2000 LX 4cyl Check Engine Light (muskrat)
Anyone else here drive this car or am I the only one?
Old Feb 17, 2003 | 07:42 AM
iam7head's Avatar
em..can you pull out the code so we can give you a hand? that's what cel are for mang.
you mention about oil change earlier, perhap check the oil level and check for any sight of leak. You got the right kinda oil right? 20w
Old Feb 17, 2003 | 08:41 AM
020's Avatar
020
that's no moon
Default Re: 2000 LX 4cyl Check Engine Light (iam7head)
did u fill the gas tank while the car was running? but, yeah, the code would be nice.
Old Feb 17, 2003 | 10:41 AM
muskrat's Avatar
Default Re: 2000 LX 4cyl Check Engine Light (Icedmocha)
Never pulled a code on a car, always heard of it, but never had a CEL come on and need to learn how, anyone tell me what to do?
No leaking oil.
Gas cap should be on tight, never fill up with engine running.
Old Feb 17, 2003 | 12:31 PM
subnet's Avatar
I have a 98 accord LX 5 spd. Around 90k mi. My check engine light came on. It ended up being the O2 sensor.
First step would be code readings.
[Modified by subnet, 4:36 PM 2/17/2003]
Old Feb 17, 2003 | 12:41 PM
muskrat's Avatar
Default Re: 2000 LX 4cyl Check Engine Light (subnet)
Once again, any help with this?
Old Feb 17, 2003 | 12:46 PM
Stew Pidasso's Avatar
You have to connect pins 8 and 13 on the data link connector under the drivers side dash. I tried to do an ASCII drawing of the diagram the 2 X's are the pins that you need to connect. After connecting these pins you need to turn the ignition to the on position without the engine running and watch the Check engine light and see how it flashes. Long Flashes are 10's places and short flashes are 1's places. I.E. 4 long flashes and 2 short flashes = the code 42. It will flash all engine codes that are in memory and then it will repeat them. Check them for accuracy and then come back on here and IM me on h-t or reply to this thread and I will look up the codes for you.
|__\
|_|_|
|_|_|_
|_|_| |
|_|_| |
|X|_| |
|_|_|_|
|_|_|
|_|X|
By CmptchAV6
[Modified by Stew Pidasso, 4:46 PM 2/17/2003]
Old Feb 17, 2003 | 08:27 PM
flrdaccrd's Avatar
Default Re: 2000 LX 4cyl Check Engine Light (Stew Pidasso)
disconnect the battery and replug it later.
"the more you let it bother you, the more it will"
Old Feb 17, 2003 | 09:05 PM
RKV's Avatar
RKV
Default Re: 2000 LX 4cyl Check Engine Light (flrdaccrd)
if u find out u need an OEM catalytic converter or o2 sensor i am selling one for sale, very cheap, its for a 1998-2002 accord 4 cylinder
[Modified by RKV, 1:06 AM 2/18/2003]
Old Feb 17, 2003 | 10:00 PM
iam7head's Avatar
Default Re: 2000 LX 4cyl Check Engine Light (RKV)
"disconnect the battery and replug it later.
is like putting a patch over bullet wound> "I'll just let this one go by, it's only my car."
[Modified by iam7head, 7:01 AM 2/18/2003]
Old Feb 17, 2003 | 11:03 PM
ratherbewalking's Avatar
its not a band aid. a band aid would be a piece of electric tape over the check engine light, or pulling the bulb for the check engine light.
resetting the ecu is a good idea, and thats what id try first, if there is a problem the light will come back on.
Old Feb 17, 2003 | 11:45 PM
Accord94DX's Avatar
could be a random misfire code that the accords throw randomly to **** people off. Clear the ECU and see if it comes on again, if so, check the code and be all like, "wassup bitch, i have dis light on mai dash and it be on and ****, what da **** do i do wit dis **** playa?"
Old Feb 18, 2003 | 04:07 AM
muskrat's Avatar
|__\
|_|_|
|_|_|_
|_|_| |
|_|_| |
|X|_| |
|_|_|_|
|_|_|
|_|X|
Hmmm, we have a problem, not really a problem, just a difference in cars. I got home and went out to jumper pin 8 to pin 13 and guess what, neither one of those pin positions have a wire running to them. In my wife's car there are only 6 wires going to the data link connector and they are located in pins 4, 5, 7, 9, 14, and 16.
I may have found the problem, I asked my wife when the last time she filled up was and she told me friday, I asked if she consciously closed the gas cap to at least 3 clicks, she told me she thought it was 1 click and she did that. So I tightened the cap and pulled the negative off the battery and reconnected it. The light is off now, but I told her to be easy on the car and watch for the light, if it comes back on we'll know it wasn't the gas cap and I'll pull a code, if I can get the right pin locations.
Old Feb 18, 2003 | 01:09 PM
I found the link... http://mywebpages.comcast.net/jweller1/check_eng.html
Courtesty of Jweller
Old Feb 18, 2003 | 08:18 PM
jweller's Avatar
Default Re: 2000 LX 4cyl Check Engine Light (ratherbewalking)
wouldn't you be just the Sliiiiiiightest bit curious about what the code was? I would be.
now, resetting it after you check it is a standard procedure. but if you just reset it and never check it, if it comes back on, you have no idea if you have thrown the same code again or if it's new one.
Old Feb 19, 2003 | 05:32 AM
muskrat's Avatar
Default Re: 2000 LX 4cyl Check Engine Light (jweller)
Well, I'm still in the dark. My wife just e-mailed and said the light came on again, she said it was at the same time as last time, just after she got over 70mph. I wanna check the code, but have no clue as to how because of how my car is different, look at this picture:
That is how you are suppose to jumper the thing to get the code HOWEVER, I do not have pins in the plug at 8 and 13. There are only 6 pins in the plug and they are located at 4, 5, 7, 9, 14, and 16. Can anyone help?
Old Feb 19, 2003 | 02:14 PM
Chiovnidca's Avatar
Jump pins 4+9. Pin 4 should be a black wire and pin 9 should be a brown wire.
Old Feb 19, 2003 | 07:16 PM
fe519's Avatar
Default Re: 2000 LX 4cyl Check Engine Light (Chiovnidca)
when you changed the oil, your probably dripped some oil on the oxygen sensor... this happened to me before. Try to wipe down the oxygen sensor wire and the oxygen sensor and hopefully that should solve your problem
Old Feb 20, 2003 | 01:56 PM
flrdaccrd's Avatar
Hey! It's been working for me for 2 years now with my Ford Taurus. I'm certainly not bitching.
Old Feb 21, 2003 | 04:49 AM
muskrat's Avatar
Pulled the code last night, it's a code 87.
Anyone know what this code means or where I can look it up?
Thanks.
Old Feb 21, 2003 | 05:10 AM
antaneus's Avatar
there isn't a code 87 count again.
Old Feb 21, 2003 | 05:29 AM
jweller's Avatar
Default Re: 2000 LX 4cyl Check Engine Light (antaneus)
yes there is, Cooling System Malfunction
Old Feb 21, 2003 | 05:31 AM
muskrat's Avatar
That's kinda vague, what should I check/replace? Thermostat, coolant level, water pump? I guess I should tell my wife to watch the temperature gauge... hmmm, does the car have one? I forget.
Old Feb 21, 2003 | 05:39 AM
carolinaACCORD's Avatar
check coolant level first, i dont think that would throw a code, but you never know.
