I got a messed up suspesion and want to put on coilovers,bad idea???
Old Feb 16, 2003 | 09:37 PM
allmotorEG-SI's Avatar
Default I got a messed up suspesion and want to put on coilovers,bad idea???
The toe on the front right tire is "off the charts" as the mechanic put it. I think because of the where the lower control arm connects to the frame, that part of the frame is slightly twisted. Now i've got a set of APC coilovers that I've had for about a year now and I wanted to put them on. Do you think it would cause major problems or what? The car damage really isnt' as bad as it sounds. You really don't even notice it when driving, the car just ever so slightly drifts right a little.
Old Feb 18, 2003 | 04:11 PM
Default Re: I got a messed up suspesion and want to put on coilovers,bad idea??? (gixxerdemon)
so no one has any ideas?
Old Feb 18, 2003 | 04:36 PM
tominos's Avatar
why don't you get an alignment?
Old Feb 19, 2003 | 03:28 PM
Default Re: I got a messed up suspesion and want to put on coilovers,bad idea??? (tominos)
It wont help. suspensionis bent.
Old Feb 21, 2003 | 07:24 AM
Ok no one knows. Well let me rephrase it. Will lowering a car with the incorrect toe setting cause any other problems with alignment?
Old Feb 21, 2003 | 08:40 AM
InspiredRacer's Avatar
Yes and no
You already have problems
If at all possible get the toe to match up front. Hopefully you can get it from .25 in to .25 out. If you can get it to somewhere around that then you will be alright. If you do not want excess tire wear; drive harder. This toe along with camber from the coilovers will give you great handleing, but unless you take corners hard; you will get uneven tire wear.
What was your toe, what drop are you doing, etc details
Old Feb 21, 2003 | 05:02 PM
Default Re: I got a messed up suspesion and want to put on coilovers,bad idea??? (InspiredRacer)
I never got the specs of what the toe was at because the guy couldnt' measue it. He said it was off the charts. I'm going to put on some APC coilovers and lower it just a little, nothing drastic.
slo_hatch
Jul 21, 2009 04:46 AM
Kangolbrand
Suspension & Brakes
10
Nov 28, 2006 09:23 PM
blkgsr03
Sep 24, 2003 11:29 AM
sslude
Jun 27, 2003 04:59 AM
alfaaay
May 7, 2003 01:25 AM
