installing strut bar
Old Feb 16, 2003 | 08:26 PM
SOHC_MShue's Avatar
Default installing strut bar
is there anything else that you have to do when installing one besides bolting it under your hood. someone told me that you have to jack your car up and compress your struts when doing it or something.
Old Feb 16, 2003 | 08:36 PM
IrishDX's Avatar
Default Re: installing strut bar (SOHC_MShue)
As long as you are on level ground, just bolt it on. The struts shouldn't move.
Old Feb 16, 2003 | 08:38 PM
SOHC_MShue's Avatar
Default Re: installing strut bar (IrishDX)
you shure?
Old Feb 16, 2003 | 09:46 PM
SSBP DC2's Avatar
lol
Old Feb 17, 2003 | 12:51 PM
genetsang's Avatar
gotta take off all the wheels.. buy a CF hood... get some Altezza tails... buy a huge aluminum spoiler.. mix match bodykit and side skirts.... and Rice out your car b4 you can put on your strut bar.... otherwise the strut bar wont line up correctly with the bolts....
Old Feb 17, 2003 | 02:03 PM
T3's Avatar
T3
Default Re: installing strut bar (genetsang)
Old Feb 17, 2003 | 02:45 PM
InspiredRacer's Avatar
Default Re: installing strut bar (T3)
front strut bars should be present on cars that oversteer out of control. Unless you have a rear sway bar, bushing kit, good alignmnet(no spec) and a front sway don't waste your money! For fwd that is
Old Feb 17, 2003 | 02:57 PM
tominos's Avatar
don't jack the car up,
1. take off nuts on shock tower
2. put strut bar on
3. tighten nuts
thats the complicated procedure to installing a strut bar.
Old Feb 17, 2003 | 06:01 PM
SOHC_MShue's Avatar
why don't you blow me noob
i was just wondering because someone told me that you had to jack your car up and do all of that other stuff. I didn't think that he was right, but i was just making sure. Thanx to everyone that responded with a helpful response.
Old Feb 17, 2003 | 06:04 PM
the DR.'s Avatar
Default Re: installing strut bar (InspiredRacer)
what?!?! front strut bars have little to no significance concerning under/over-steer...
Old Feb 17, 2003 | 06:16 PM
genetsang's Avatar
i might me a new to H-T... but whos the one with the problem intalling a front strut bar..... could it be you, NOOOBIE.... as for blowing you..... i prefer ramming your moms ***** up your anus... so knock it off with the childhood jokes.
maybe youll need help putting on your windshield LED's too
onto the new topic
Old Feb 17, 2003 | 07:12 PM
SOHC_MShue's Avatar
ok sorry i asked a question *******. It was a resonable question and you don't need to be a dick about it. If you don't have anything important to say then you don't need to post on the topic. I knew that all you had to do was bolt it on, but someone told me something different and i just wanted to make sure i wasn't wrong.
Old Feb 17, 2003 | 08:08 PM
cleanASScoupe's Avatar
chill out n00b.
sohc, just make sure you're on level ground, thats all.
Old Feb 17, 2003 | 10:17 PM
iam7head's Avatar
Default Re: installing strut bar ('99EJ8)
sohc: try it without jacking the car up.
something it wont fit in because lowering issue then jack it up.(0.01percent of time)
Old Feb 18, 2003 | 09:32 PM
SOHC_MShue's Avatar
Default Re: installing strut bar (iam7head)
alright i found out why my friend thinks you have to jack the car up and do some adjusting so the strut bar pushes outward. Read this thread he found on a DSM website and tell me what you think about it. http://www.dsmtalk.com/forums/showth...threadid=79504
Old Feb 18, 2003 | 09:41 PM
Default Re: installing strut bar (SlicedBread)
Never respond to a suspension or handleing question again.
What on earth do you think the upper support brace does? This is not an appearance mod
Old Feb 18, 2003 | 10:24 PM
SOHC_MShue's Avatar
anyone look at that link yet?
Old Feb 18, 2003 | 10:40 PM
the DR.'s Avatar
please explain in detail how they affect understeer/oversteer? i'd really like to be educated here...
i've came to the conclusion that strut braces only helped to stiffen the chassis, which would be a chassis item, not neccesarily a suspension item, in theory, i can see where you're coming from, but i doubt a car will 'flex' enough to change an alignment angle so dramatically that it would induce/reduce an oversteer or understeer condition..
[Modified by SlicedBread, 7:58 AM 2/19/2003]
Old Feb 19, 2003 | 09:55 AM
SOHC_MShue's Avatar
look at that link and tell me what you think about it.
Old Feb 19, 2003 | 10:29 AM
ForeignConcepts's Avatar
just out of curiocity why would you drop suspension by lifting the car only to have to try and compress the springs again? ? ? ? ? ? ? ? ? ?
is it me or did the guy telling you this want to use your car in part of some silly autocide or somethin? could just wanted to see you work twice?
[Modified by ForeignConcepts, 7:31 PM 2/19/2003]
Old Feb 19, 2003 | 12:12 PM
MattG's Avatar
New User
IT makes sense but, ideally rather than jacking the car up I would want to take measurements for the correct distance of the shock/strut mounts. You don't want to pre-load the setting more than needed. I could easily see every car being different. Some may push in on the bar others may pull out. It depends on the "correctness" of the suspension geometry (ie if the car was in an accident). For most purposes though if the bolts aligne well it should work. The idea is that the bar holds the damper mounts in place when cornering. Assuming the geometry of the setup is correct while the vehical is resting simply installing the bar as mentioned(just bolt it on) should be fine.
BodyKits NW
Welding / Fabrication
Dec 27, 2007 10:00 AM
Dforce
Apr 5, 2005 07:40 PM
Tippolas
10
Aug 2, 2004 06:18 PM
littledan
Apr 28, 2004 07:40 AM
eight-six
Nov 9, 2001 06:58 PM
