6th gen offset
Yeh, the Accord is 4x114.3 bolt pattern ( 4 x 4.5" if you prefer)
The offset is in the neighborhood of +50mm (stock), I believe as well. It maybe even higher say +55mm. +42mm IMO of the largest offset aftermarket wheel you should source as well. Running +42mm 18" Racingharts and man are they close to rubbing.
On V6 stock rims are +55mm offset, I think it should be the same on I4
Depending on what rim diameter/tire profile/drop you wanna run you should be
taking offset into consideration.
MugenPoweredLude
Dec 23, 2002 12:09 AM
xunkn0vvnx
Sep 14, 2002 08:21 AM
