5 lug practicality?
Do 5 lug suspension swaps pose any benefits for you Integra guys, besides the cool uniqueness of it? I realize it probably allows you a wider wheel selection, but any actual benefits? I am wondering if it's worth looking into for my EP3...
bigger rotors = more rotating mass = blah
1 more lug = even more rotating mass = blah
wheel choice in 4x100 is not much less than 5x114.3
now if you were to autoX and need better brakes, just get a big brake kit for less $
Yes but you had to buy new wheels. For $300 you can get better brakes than stick ITR, sorry but its true. 11.1 inch rotors @ 28mm thickness and 2 piston calipers. I really dont care about the "coolness" factor, and i think its a waste of $ to get 5 lug because its Ko0l yO
you think it aloows for a better wheel selection ? hahahaa , you got seomthing coming .
mostly all hondas are 4 lug, so why would they make more wheels in the not so popular 5 lug ?
i dunno i dont think its worth it to convert, its just the bling factor to say hey. i have 5 lug like a type R , . . . . JDM YO
Let me clarify. I got the ENTIRE system for $400. Thank you drive through.
I mean seriously, when you're actually using those brakes for what they were intended, nobody will be able to tell how many lugs you have
[Modified by PatrickGSR94, 3:31 PM 2/19/2003]
there is one big reason to consider switching, but if you don't know what it is, you probably won't bennefit from the change.
the thing is, that if you are autoxing, every time you take a corner you are putting a lot of load onto your wheels, and that gets transfered through 4 points into the rest of your car. 5 lugs transfer that load out just a little bit more and make for a less stressful corner on your wheels.
it is nothing you can feel, it is nothing you can see, in fact there is no way that a you will in any way notice the bennefit, but it will be there.
if you are considering doing it because it is cool, put your money in your pocket and buy yourself a nice set of golf clubs, that is much cooler than rollin 5 lugs deep for no reason at all.
A 2600-lb or lighter Honda will never overstress 4 lug nuts and studs if properly torqued.... ever. If so they would have made all their cars 5-lug.
I saw some pictures of a Japanese race where they used a s2k i believe. Anyway 3 of the lugs broke off after the day. And the wheel was still on the car. If it was 4 lug, by by wheel.
big brake kit??
but i though "bigger rotors = more rotating mass = blah"
blah blah blah
And wheels and tires? Didn't think so.
Thinks HATERS SUCK
