axles for b20b swap
Old Feb 16, 2003 | 07:55 PM
PI_tony41's Avatar
Default axles for b20b swap
Which axles and ecu do I use for a b20b into my CRX. Do I use the abs ones or the non-abs ones. Thanks
Old Feb 16, 2003 | 08:10 PM
Blaze45's Avatar
Brrraaaap!
Default Re: axles for b20b swap (PI_tony41)
90-93 teg axles. non abs.
Blaze
Old Feb 16, 2003 | 10:41 PM
sparkz's Avatar
Default Re: axles for b20b swap (Blaze45)
Blaze
depends on which halfshaft you are using. if youre using the original b20b one, its hte same as a gsr and manual ls. you will need a driver side 94+ integra axle and for the passenger you can use 88-89 integra axle. you can use a 90-93 teg axle for pass. side but its a lil too long.
mikester1222
Jan 22, 2007 06:11 PM
b16crx0062004
Nov 17, 2004 06:13 PM
BlackNoise
Feb 10, 2004 10:26 AM
foursquarepunk04
Feb 3, 2004 08:42 PM
