swap help!!!
I have a 91' crx Si , and im trien to drop in a 93' integra motor. Its all in but when you press the clutch pedal in it just falls to the ground and it doesnt come back out. I was wonderin if anyone has had this problem befor? The only thing i was thinkin about was the actual tranny cable, i still have the crx cable in it. Do i have to change this out to an integra cable? Please help , thanks......
open the hood and pull the clutch lever and see if the clutch engages and disengages if the lever is fine then there is no problem with the clutch and it has to be the way you have the cable adjusted
Nutnwrench
Jun 18, 2008 08:55 PM
slayerP
Apr 5, 2008 01:34 PM
