97 civic turn signal ????
Old Feb 16, 2003 | 06:46 PM
autorpm's Avatar
Default 97 civic turn signal ????
I have a 97 civic ex and it was stolen. Since recovered and fixed , my turn signals dont always cancell. This happens expecially when it is cold out side. when warm they usually work. As I am and dont want to bring it back to the bodyshop,I was wondering if anyone has ever experienced this problem and how to fix it. I am a liscenced technician by trade but have been in the parts side of the buisness for the past 4 years due to back problems so I am sure I can fix it if I could get directed in the right direction
Old Feb 16, 2003 | 06:50 PM
Audi RS4's Avatar
Lover
Default Re: 97 civic turn signal ???? (autorpm)
sounds like your wire insulator (the plastic coating) is cut or ripped somewhere and when it is cold there is moisture in the air and shorts it out. just a thought, grab a haynes manual and trace the wire... good luck!!
car thieves
[Modified by AK1200, 7:51 PM 2/16/2003]
Old Feb 16, 2003 | 06:58 PM
Audi RS4's Avatar
Lover
oh yeah, one more thing. go ahead and replace the relay they are cheap and it wouldn't hurt to try..
Old Feb 16, 2003 | 08:00 PM
gumbii's Avatar
Default Re: 97 civic turn signal ???? (AK1200)
did they break the column lock thing...?? the turn signals are canceled when the steering wheel unwinds the other way.... when the turn signal is used... a little tooth pops out and rubs against teeth conected with the steering wheel.... i think you need another set of turn signals switches..... i think.....
Old Feb 17, 2003 | 07:21 AM
autorpm's Avatar
THANKS FOR THE INFO WILL TRY OUT SOON
ahelton12
May 24, 2017 05:15 PM
DinduNuffin
Jul 20, 2016 08:39 AM
1997exciv12w3
Oct 10, 2002 05:43 PM
