Oil consumption?
Old Feb 16, 2003 | 04:27 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Oil consumption?
I've recently began to worry about my R and its ever increasing consumption for oil. I eventually switched from Mobil 1 to normal Castrol GTX to try and lower its oil use but it hasn't helped. On average I go through 3-4 quarts every 3,000mi. I basically have to add oil every time I stop for gas. My compression is good and the car still runs pretty strong ( I trap 100.89mph with 173whp), but its getting a little out of hand. How much oil do you guys go through? As long as I keep a check on it is there any real reason to worry? Is it hurting my performance?
< thinks of it as another reason to start his 2.0liter NA B18C project.
Old Feb 16, 2003 | 04:40 PM
RagingAngel's Avatar
Default Re: Oil consumption? (ActiveAero)
Mine's pretty moderate....
depends on my foot really.....
Did a 9hour trek to another province...stayed in VTEC for like 2-3hours at a time.... went through 2liters in about 400miles.
Do a leakdown test...it's better than a compression one if you are concerned....might show some other clues....
Old Feb 16, 2003 | 04:44 PM
sgT's Avatar
sgT
try increasing theweight.
if you use 5-30 try 10-40 or 20-50
Old Feb 16, 2003 | 05:01 PM
B U N M A N G O's Avatar
I tried starting other threads here and in the Integra forum, and sadly nobody posted anything too useful. The most common suggestion was to go back to conventional oil from Mobil 1 synthetic, but that didn't help me out. Changing valve seals didn't help any at all either. I suppose I should get a leakdown test done but I haven't gotten around to it yet. Any suggestions on where to go for a cheap leakdown test in the LA area?
Old Feb 16, 2003 | 05:25 PM
Tweakmeister's Avatar
some guys with gs-r's were replacing valve seals
edit\\ let me check on that...maybe it was the guides? gah....
[Modified by Tweakmeister, 9:26 PM 2/16/2003]
Old Feb 16, 2003 | 05:27 PM
sgT's Avatar
sgT
Default Re: Oil consumption? (Tweakmeister)
seals, not guides
If oil consumption can come from a number of places.
if it smokes at idle or cruise then you change the valve seals.
if it smokes under load(throttle) then its rings.
and remember, the smoke has to be blue
Old Feb 16, 2003 | 05:46 PM
Dirt's Avatar
Default Re: Oil consumption? (sgT)
Like Steve said, I would experiment with a 10w30, 10w40 or 15w40.
Old Feb 16, 2003 | 06:04 PM
sgT's Avatar
sgT
Default Re: Oil consumption? (BrewCityR)
well, 10-30 and 5-30 are the same weight.
Old Feb 16, 2003 | 06:10 PM
seals, not guides
Well another thing to check for might be the PCV if the car is older...
I've had mine cleaned out and checked, replaced with a newer one to test and it seems to have cut down on the consumption a bit.
When I was doing the Hondata IM gasket install (still shook from that experience hehee) I noticed a fair amount of oil pooled inside the IM.
Where do you think the oil goes? Coupled with a test pipe....it makes for some wonderful smoke rings.....
Old Feb 16, 2003 | 08:39 PM
Dirt's Avatar
Different HTHS (High Temperature/High Shear... rated at 302*F) #s though.
Old Feb 16, 2003 | 09:10 PM
sgT's Avatar
sgT
and why is that
Old Feb 16, 2003 | 09:20 PM
Dirt's Avatar
http://theoildrop.server101.com/ubb/...c;f=1;t=001392
10w30 will have a higher HTHS (high temp viscosity basically) than a 5w30. I just suggested a 10w30.... if that doesn't help consumption, try a 10w40 or 15w40. They will have a higher HTHS #.
Old Feb 16, 2003 | 09:27 PM
sgT's Avatar
sgT
According to those numbers thats not exactly true.
A lot of the HTHSfor 5-30 and 10-30 are the same, and they are mfg specific.
Old Feb 16, 2003 | 09:33 PM
98cwitr's Avatar
my R is pretty stock (I/E) but I dont use a drop
<---- uses valvoline synpower 5w-30 will over 71k miles
[Modified by 98cwitr, 1:35 AM 2/17/2003]
Old Feb 16, 2003 | 09:42 PM
Tommy_Gunns's Avatar
I burn about 0.5 litres between oil changes. I've never loss so much oil such that VTEC would not engage.
Old Feb 16, 2003 | 09:50 PM
EK MONEY's Avatar
Default Re: Oil consumption? (Tommy_Gunns)
on my old R (98) I was looking at 2 quarts between change. that was never boosted on or squezed.
Old Feb 16, 2003 | 09:55 PM
Default Re: Oil consumption? (Peagreenhatch)
I'm wondering if there's a direct correlation between B18C's and using Mobil 1 Synthetic... how many of you have oil consumption problems with Mobil 1? My previous poll didn't work out too well =\
Old Feb 16, 2003 | 10:01 PM
Dirt's Avatar
Steve that is true. 10w40 really does increase over both. I guess I was thinking more on the lines of many people here on H-T consume Mobil1 5w30 and the ones who tried M1 10w30 had reduced consumption, including myself in my old '94 GS-R I had. Being manufacturer specs, they could be a guess too but it's a fair reference to compare same brands, but different weights of oil.
Old Feb 16, 2003 | 10:54 PM
Aussie_ITR-0239's Avatar
New User
Only about 0.5-1.0 Litre of Castrol 'Formula R' 5w-30 synthetic oil.... every 10,000 kms (~6,200 miles) and usually when I've done a track day or driven the car 'hard' in hot weather. Pretty good for a car that's travelled 80K miles and done 12 or so track days!!
Get your car checked out properly dude.... as no engine should be dropping or consuming that amount of oil, in the time you specified.
Old Feb 19, 2003 | 08:44 PM
myhatchrips's Avatar
dont trip bro i use 3 quarts every 3000 miles and im using 10-40 valvoline. my compression checks in at 225 on all 4 cylinders. using a special diagnostic tool called a borescope, i found where all my oil is being burned at. basically a borescope is like a magnifying glass that you insert into the cylinders and check the condition off the cylinder walls. my #3 cylinder has one scratch going up and down which pretty much defeats the purpose of having a properly honed cylinder wall. the cylinders have a crosshatch with a 60 degree pattern. so all it takes is one scratch on any of your cylinders and boom you have oil burning problems. hope that helps
Old Feb 19, 2003 | 08:46 PM
i agree they are the same once your at normal operating temperature. otherwise 5-30 is thinner only when cold to provide easier startups in cold areas.
Old Feb 19, 2003 | 08:52 PM
Default Re: Oil consumption? (myhatchrips)
did you get a leakdown test done too? where'd you get access to a borescope?
Old Feb 20, 2003 | 10:05 AM
Default Re: Oil consumption? (bunmango)
automotive tech class
Old Feb 20, 2003 | 10:19 AM
swlabhot's Avatar
When I had Mobil 1 5-40, it did not loose a drop. Came oil change I thought I'll try Castrol Magnatex GTX and its drinking quite a bit...
I will be switching back to Mobil 1 to see if there is any difference.
Old Feb 20, 2003 | 10:43 AM
Haunt's Avatar
I dont use synthetic because of this reason...
