Anyone has the Mugen N1 ECU?
What's the requirement for the Mugen N1 ECU? fit for USDM 98 type R?
needs any modifications?
Is it need for the Mugen valve spring set?
What's the performance gain? big differences? dyno anyone?
I have not had a chance to dyno yet.
This ECU is for racing use only.
You will get about 8 mpg with the ECU.
What are you trying to gain by changing the ECU? There may be a more cost effective way to achieve your goal.
Therefore, you think Mugen ECU won't help for the I/H/E?
coz my friend is using it ..........he said it has a lot differences?
especially when the VTEC kicks in..........
I can't comment on gains with the ECU, because I haven't dynoed it. I don't believe in using the butt dyno to make claims.
hey, you re from BC...so am I
btw, your money could be better spent elsewhere if you don't get the ecu
It's nice but not worth the money IMO...I recommend you looking for a toda header and carsound cat
Because I think Mugen ECU is for N1 races.......
Therefore, eventhough you don't have I/H/E ..........you should still have gains from it .........right?
If you're not limited there are better options out there.
need to splice some wires if you want your A/C to work...not worth $1300 IMO
