built head ?
Old Feb 16, 2003 | 04:10 PM
unknown317's Avatar
Default built head ?
I just got my 2000 ls and so far all i have is a CAI. My friend is swaping his motor and will sell me the head off his old fully built ls motor for $350. Its got about 8000 miles on it but its got crower 403's, springs, retainers, venom cam gears, 3 or 5 angle valve job ect... I am for sure buying it but when i get it i got a few questions?
1. Should I worry about buying a used head? He had it tested at a shop here and it tested out fine. I know that it sat in the garage for a while while the car was getting the body work done.
2. I do not have the money to get a header after getting the head so should i put on a stock type R exaust manifold that I happen to have or should i just wait a bit longer and get the header. I would think that the type r manifold would flow better then the ls.
3. Do you think by bolting on this head I could gain a good 25 hp?
Thanks for the info
Old Feb 16, 2003 | 04:21 PM
threatcon13's Avatar
New User
Default Re: built head ? (unknown317)
Thanks for the info
1. if hes really a friend, nothing to worry about.
2. I guess you could use the stock type R but a 4-2-1 is better for the b18b's power band.
3. depends on quality of port/polish, but probably 10-20.
Old Feb 16, 2003 | 04:41 PM
unknown317's Avatar
Default Re: built head ? (Threatcon13)
also, I know the honda head gaskets are 3 think. If you remove one it will raise the compression right? I know its not much but will it be more vonerable to blowing a head gasket or leaks?
Old Feb 16, 2003 | 05:06 PM
New User
they are layered headgaskets...but you cant just go removing layers like that. you can buy a thinner headgasket such as a mugen which will raise compression. mugen raises by .4.
Old Feb 16, 2003 | 05:25 PM
JeremyL's Avatar
put the head on your motor and boost it, LS's with opened up heads really respond well
Old Feb 16, 2003 | 05:28 PM
New User
Default Re: built head ? (JeremyL)
lol. he doesnt even have enough money to buy a header, how is he going to sleeve/get internals and a turbo kit.
Old Feb 16, 2003 | 05:34 PM
unknown317's Avatar
Thats right i am a poor college kid. But i just got the specs on the head....
crower 403's, venom cam gears, max port, 5 angle valve job and tyrp r springs and retainers and a AEM fuelrail. Seems like a good head. Any comments?
Old Feb 16, 2003 | 06:07 PM
SiR-DC2's Avatar
Actually 403s w/ all the work AFTER major tuning I would EXPECT 15-20 hp but only if you have an SAFC (or some fuel tuning method) and chipped ecu (to max. power from the cams).
Old Feb 16, 2003 | 07:37 PM
unknown317's Avatar
Default Re: built head ? (SiR-DC2)
But i would say its worth $350.
Old Feb 16, 2003 | 07:43 PM
SlowPoke's Avatar
New User
definately worth the 350 bucks if none of the parts are f'ed up. I mean brand new, the cams are 400, cam gears are around 200, and etc. not to mentio head work. If everything is in good working condition, then I think your friend is really hooking you up
Old Feb 16, 2003 | 08:33 PM
unknown317's Avatar
Default Re: built head ? (SlowPoke)
I just talked to him about it and he took it into a shop here that he had build it and they took the cams out cleaned it, lubed and reinstalled the cams and fixed 2 of the cam bolts that were stripped. They said that it was in excelent condition and was ready to be put on a car.
B18T3T4
Nov 26, 2006 06:35 AM
B18T3T4
Nov 23, 2006 03:35 PM
Nors
Jun 6, 2006 03:50 PM
turbo_ef9
Aug 28, 2002 03:32 PM
Blackack
Apr 4, 2002 11:22 AM
