So what does this mean?
Old Feb 16, 2003 | 04:00 PM
Dancing is Forbidden's Avatar
Default So what does this mean?
Is this normal when you disassemble an engine? Or is something wrong? LMK. Thanks.
Old Feb 16, 2003 | 04:02 PM
poison's Avatar
Default Re: So what does this mean? (EF9_SiR)
looks like a POS headgasket is all I see. Other than that, the motor and sleeves look good, just probably might need a rebuild.
Old Feb 16, 2003 | 04:03 PM
Default Re: So what does this mean? (poison)
We are rebuilding it completely. I was just wondering if I was sold a bunk engine. Thanks.
Old Feb 16, 2003 | 04:06 PM
abraunworth's Avatar
New User
well, if you are rebilding it completely, unless it has a cracked block or cracked head, then it doesn't really matter anyway.
Old Feb 16, 2003 | 04:11 PM
poison's Avatar
Default Re: So what does this mean? (abraunworth)
once you take apart the short block, I would rehone the block/cylinders just to make sure it's perfectly round.
SikofFalln's Avatar
Doesn't look to bad to me.
Old Feb 16, 2003 | 04:16 PM
StinkyTofu's Avatar
Default Re: So what does this mean? (BseriesPWR)
Looks like it was running pretty rich. If you think about it, its not that bad. Think about how many explosions occur inside your combustion chamber.
Old Feb 16, 2003 | 04:27 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: So what does this mean? (StinkyTofu)
looks good. Machine shop here you come!
Old Feb 16, 2003 | 04:31 PM
4g4me's Avatar
You are rebuilding the engine
and you dont know if a motor is good by looking at it?
Boom
Old Feb 16, 2003 | 04:32 PM
Default Re: So what does this mean? (Emerica)
Do you think I should leave the head pretty stock? And where can I pick up a Helms manual?
Old Feb 16, 2003 | 04:36 PM
Noe Kozz's Avatar
Default Re: So what does this mean? (4g4me)
Boom
That's why we have Honda Tech, for people like him to get on and ask these questions.
Old Feb 16, 2003 | 04:38 PM
sshaikh01's Avatar
it looks like a single cam
why are you building that
Old Feb 16, 2003 | 04:41 PM
Boom
I was just asking because when we pulled the heads on my friends 350 it looked a lot different. Excuse me for asking a question. and it is a B18a1, for the person saying it looked like a SOHC.
Old Feb 16, 2003 | 04:42 PM
poison's Avatar
it does look like an sohc lol...
I understand he's askin, just wanted input from other engine builders with more experience probably to make sure nothing appears different than the norm on the block.
it was a legit question.
Evs-One's Avatar
Solbros Owns Me
Boom
I built my first engine when I was 17. Didn't know ANYTHING about internals, just asked a local old guy all the time. Engine came out mint and still running to this day.
The engine was a mildly built 350 for my 70 Chevy truck. Performance cam, Edlelbrock crap, etc. I assembled EVERYTHING except cam bearings and piston pins and machine work. Puppy is still purring.
True, it is good to read up first, but learn as you go. Nothing is worth more than hands on experience.
Old Feb 16, 2003 | 06:50 PM
PupaScoopa's Avatar
Explosions??!?!?? You should only get explosions when there is detonation. Otherwise, the fuel/air mix is burning at a certain rate.
Old Feb 16, 2003 | 08:07 PM
piscorpio's Avatar
Tell it brotha!
Appreciative knucklehead who plans to dive headfirst into engine building, with nothing more than a Helm's and a prayer.
Old Feb 16, 2003 | 08:14 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: So what does this mean? (piscorpio)
Tell it brotha!
woops.....
haha, with God on your side and the Helms as your guide, anything is possible
Edit- it's all about clearence and torque
[Modified by Emerica, 9:15 PM 2/16/2003]
Old Feb 16, 2003 | 09:03 PM
b18b-HB's Avatar
Old Feb 17, 2003 | 09:25 AM
initial-dc2's Avatar
it looks good the head gasket just looks old nothing un fixable it looks like a good engine to rebuild
Old Feb 17, 2003 | 09:30 AM
racecarpete's Avatar
Default Re: So what does this mean? (initial-dc2)
looks fine, nothing out of the ordinary, have fun.
Old Feb 17, 2003 | 09:51 AM
tek_civic's Avatar
let us know how it goes. i plan on buying a spare d16z6 and setting it up on a stand and ripping into it. if i get it to work i will swap it for mine.
Old Feb 17, 2003 | 09:58 AM
acydphryck's Avatar
that's normal...like the other people mentioned, i'd have that thing honed out. also, looks like the motor was running a little too rich. you gonna be using the same pistons and stff for it?
Old Feb 17, 2003 | 10:02 AM
ill phil's Avatar
woops.....
Pretty much. If you make sure all the clearances are good, assemble the parts where they need to be , and torque down to spec you should be good
emu103
21
Feb 16, 2012 06:31 AM
NOTDISFA5
15
Oct 25, 2010 04:52 PM
kte324
Oct 19, 2009 12:25 PM
classciv
18
Jul 31, 2006 06:36 PM
FOrSfEd
Mar 23, 2004 05:54 PM
