90 crx and sohc vtec
i want to use the stock 95 vtec distributor and ecu, can it be done? what ing harnesses should i use?
[Modified by stupidfast, 5:42 PM 2/16/2003]
then u need to repin the Distribuitor...
u can use the stock harness..
for example.. with blownhatch conversion harness u got all the instructions u need.. repinin it means u going to take the cables off the plug and put it back in in a idfferent order.... the corresponding way as they go into the ecu
you need the driver side mount that came with the vtec motor
http://www.angelfire.com/ca/DrOhm/hybrid.html
heres what i used, its pretty good, but no one ever mentions the fact you can use a PR3 ecu w/ knock disable and it runs GREAT and all you have to do is run two vtec wires
robichaux
Apr 7, 2004 11:25 PM
JdM_HoNda
Jul 9, 2003 10:44 AM
ProjectCRXtacy
May 3, 2002 01:17 AM
