Ways to do LS/CRV-TEC conversion.
I remember seeing in a magazine one day a b20 vtec conv. They used the stock vtec supply hole in the head and drilled one in the block to match it. I did a search and the only how to stuff I found was c speed racing's conversion where they ran an oil line off the back of the block. I would much rather opt for the first method over the second. It is how Honda designed it, and I feel better about doing it that way, besides that there are plenty of lines in my engine allready, don't want to add more. Are there any on-line resources that cover this conversion?
Also I planned on using Haltech engine management, so all the knock sensor bullshit is not needed correct?
Also I planned on using the Venom sheet metal instake. All the little stock sensors from the factory intake don't seem to have any mounting locations. Or at least that is the case on all pics I've ever seen. What must be done? What about the IAC I do beleive that is necessary? Since I'm going to be running Haltech are these not necesary? Thanks alot.
do the external oil line.
where did you see the internal one?
sounds suspicious to me...
since you are standing it alone, dress the IM to suit...
t..
t..
It was in either Super Street or Sport Compact car it was probally over a year ago.
I just read some **** about oil squirters being absent in LS/CRV blocks has anyone found away to add these. The Z-10 block girdle is deffinitly on my to buy list. Anyone have a CRV-tec with out the squirters and have had any problems?
how much boost are you planning?
why not start with a B18C?
t..
id say that 90-95% of LS/CRVTEC's do not have oil squirters installed.
t..
t..
OK so it sounds like you are planing some serious boost.
well, dead straight, you cant do that on stock sleeves, they will break.
get goldern eagle or similar and forged pistons.
good luck.
t..
PS the oil squirters are for cooling hte stock cast pistons at hi rpm, once you go forged, this requirement is reduced...
good luck.
t..
Sorry man, I guess I was vauge on what I planned on doing. The Golden Eagle sleeves were part of this project since it's conception. I was planning on running JE 9.0:1 84.5mm pistons, Eagle rods, and definitly z-10 girdle and ARP head studs, and rod bolts. That should provide a somewhat bombproof bottom end. Those damn squirters still make me nervous though.
So you are saying don't worry about it, you're a paranoid fucknut, right? Just give it to me straight. I just read a bunch of neg. CRVtec stuff yesterday because, I was sick at home doing a bunch of research on motors. Just tell me they are morons, and Built CRVtec Turbos are one bad motha f%#$ing setup. Even if they don't have oil squirters.
www.swaintech.com
the oil squirters wont stop you cracking a B20 sleeve... (your MAJOR concern)
in fact i am not sure what the oil squirters will do except transfer the combustion heat to the oil...
if you want it straight,
i reckon you are worrying with the details and missing the point.
a B20 is not as strong as a B18, if you wanna see past 250HP tehn you may as well start with a bored and sleeved B18C...
that is my opinion. that is all...
it is your choice. dont let the internet decide your life.
t..
t..
Ok, I won't get hung up on the details then. I will build the crap out of it, GE sleaves, JE pistons, Eagle rods, Z10 block girdle, all ARP hardware. I was really planning on doing that anyway I just wanted some positive reinforcement for my actions. I know there are a good amount of B20VTEC Turbos out there, just wondered how reliable they were. Oh yeah WTF does "tap it from the back" have to do with any goddamn thing?
Oh I get it now tap it from the back. Just like I would love "tap" Sarah Michelle Gellar, from the back. The oil line needs to be tapped from the back too. I though your just being a smart *** punk. Gotcha now thanks for clarifing. I got so caught up about the damn squirters I forgot about what I even started talking about.
