Fuel Press. Reg.'s, Fuel Rails, Pumps, and Injectors
Old Feb 16, 2003 | 03:21 PM
Brett's Avatar
Default Fuel Press. Reg.'s, Fuel Rails, Pumps, and Injectors
If I get a better fuel pump or a booster does that change my a/f ratio? When dyno tuning do you adjust your fuel press. reg. to adjust your a/f ratio? Does changing out the fuel rail or injectors change the a/f ratio? I would like to upgrade my fuel system to avoid detonation w/ n20 but would like to find out if I need lots of tuning after this.
Old Feb 16, 2003 | 03:31 PM
PM-Performance's Avatar
Default Re: Fuel Press. Reg.'s, Fuel Rails, Pumps, and Injectors (Brett)
yes it will changes in pressure and amount of flow will change te mixture , you will need to get it tuned for maximum efficiency and power.
Old Feb 17, 2003 | 06:57 AM
zilverz's Avatar
in the meantime... you can properly reset the ECU to let it recalibrate itself
big juan
Oct 29, 2005 06:59 AM
Shadow Templar
Jan 30, 2004 08:25 PM
Joel_MN
Aug 17, 2003 11:59 AM
spcmotorsports
Oct 9, 2002 05:24 AM
