What should i do next that would be most beneficial!?
Old Feb 16, 2003 | 03:04 PM
user 996328629's Avatar
Default What should i do next that would be most beneficial!?
I have a AEM intake, N1 Exhaust, and im getting a DC Sports header. I was thinking about getting a VAFC or fuel stuff (rail,fpr) or autometer gauges or NX Express...Im lost on what i want to do, and what would help me out. Any ideas?
Old Feb 16, 2003 | 03:08 PM
Brett's Avatar
Default Re: What should i do next that would be most beneficial!? (Swags04)
I've had good luck with n20.
Old Feb 16, 2003 | 03:14 PM
threatcon13's Avatar
New User
you dont need rail or fpr w/ your mods, nor gauges. get a new clutch/flywheel.
Old Feb 16, 2003 | 03:16 PM
B18Flip's Avatar
Default Re: What should i do next that would be most beneficial!? (Threatcon13)
Yep, it even says that in your sig
Old Feb 16, 2003 | 03:20 PM
Default Re: What should i do next that would be most beneficial!? (B18Flip)
I got a Exedy Clutch..
Old Feb 16, 2003 | 03:21 PM
I was thinking about a SK2 Manifold, but i want to go turbo aventually. And i wasnt sure if i was going to need a chipped ECU..so i kinda excluded the manifold..The gauges would be somthing that would look nice..and be helpful.
Old Feb 16, 2003 | 03:23 PM
gumbybum's Avatar
get a short shifter.. they are fun
Old Feb 16, 2003 | 03:25 PM
gumbybum's Avatar
Default Re: What should i do next that would be most beneficial!? (gumbybum)
oh ya what does a skunk2 manifold have to do with a turbo?? you can still use them together cant you????
Old Feb 16, 2003 | 03:31 PM
New User
if youre going turbo then just save your money. you want to have some money set aside just in case something goes wrong. trust me.
Old Feb 16, 2003 | 03:34 PM
B18Flip's Avatar
Cool you got the clutch covered. If you're planning on going turbo down the road, I'd suggest getting a hondata unit w/ the boost option. Since you have a 95 obd1 gsr, it'll be close to what a vafc would cost and do a WAY better job. Then when your ready for turbo, all you might need for your fuel setup are injectors. BTW you can run a hondata w/ the boost option on a n/a car
Old Feb 16, 2003 | 03:37 PM
New User
true but no need to waste money on that until you actually need the tuning done. (post turbo )
Old Feb 16, 2003 | 03:47 PM
Exactly, the turbo is about a year away..So i mean, im looking for minor bolt ons.. that i will see diffrences in..
Old Feb 16, 2003 | 04:00 PM
New User
theres nothing u can really do at this point...might as well save more for other things like hondata, injectors, boost controller, turbo timer, a/f, boost, oil pressure gauges, money for spare block, etc.
Old Feb 16, 2003 | 04:02 PM
neo1z's Avatar
Yes, you just need to save up if youre sure youre going turbo.
Old Feb 16, 2003 | 04:04 PM
Default Re: What should i do next that would be most beneficial!? (neo1z)
Well the reason im doing turbo next year, is because ill be out of highschool, and be able to afford mishaps, and ill have a beater..I also am looking into some seats, itr valve cover, gauges, vafc, Rear upper and lower strut bars..some full coilovers..
LunchboxZT
May 8, 2007 06:14 PM
liftandcut
Nov 1, 2006 05:58 AM
stockLS
Jul 7, 2003 04:49 PM
2000 Integra R #760
Sep 23, 2002 12:50 PM
insnimprtguy
May 2, 2002 11:30 PM
