B16 Vacumn Dash Pot q
Old Feb 16, 2003 | 02:57 PM
zCivic's Avatar
Default B16 Vacumn Dash Pot q
This item right here.
Can I run a vacumn from this dash pot to the FPR vacumn line?
Seen some diagrams but that looks like a hella lot of changing and also using the metal vacumn hoses that run into the factory intake. If I cann't run it to that dashpot can I run it to the vacumn thats in the rear underside with a T?
Old Feb 16, 2003 | 03:26 PM
Jared's Avatar
Default Re: B16 Vacumn Dash Pot q (zCivic)
If you'll look at the same dashpot on the 90-93 integra intake, its meant to be run into your intake pipe before the throttle body. leaving it open wont cause any problems either.
Old Feb 16, 2003 | 03:33 PM
zCivic's Avatar
Default Re: B16 Vacumn Dash Pot q (Jared)
right, know that, so I have to T the FPR with the vacumn on the backside of the intake and leave it open
Old Feb 16, 2003 | 05:57 PM
Cory man's Avatar
I capped mine off. Car runs the same. hth
Old Feb 16, 2003 | 08:41 PM
RCautoworks's Avatar
Default Re: B16 Vacumn Dash Pot q (Cory man)
I left mine open to, no problems at all.
[Modified by 90blackcrx, 11:41 PM 2/16/2003]
Old Feb 17, 2003 | 07:11 AM
zCivic's Avatar
So I leave the dash pot open/or plugged which ever and I T the FPR with the valve in the backside of the manifold correct.
nf performance
May 17, 2010 04:22 AM
ALL IMPORT
May 3, 2008 08:40 PM
eagleclawracing
Jan 14, 2006 09:00 AM
speed_racer012
Nov 9, 2005 06:40 PM
integranator
Oct 17, 2004 10:30 AM
