zc swap pain in the rear coad 8 and code 10
Old Feb 16, 2003 | 02:55 PM
crxdohczc's Avatar
Default zc swap pain in the rear coad 8 and code 10
i think i have everything wired right per dx to zc instructions. but check eng light is one and its truning over but wont FIRE. AHHHHHHHHHHHHHHHHHHHH!!!!!!!!!!!.
Old Feb 16, 2003 | 03:05 PM
wannab20hatch's Avatar
Default Re: zc swap pain in the rear coad 8 and code 10 (crxdohczc)
Code 8 is TDC position. (Top Dead Center)
Code 10 is IAT. (Intake Air Temp) Ive got code 10 on my car w/o a swap and its a pain in the *** to fix.
Old Feb 16, 2003 | 03:06 PM
2dregcivic757's Avatar
I just got my ZC swap done in my 90 CRX Si and my check engine light wont go off. My radiatior fan wont come on either.
Old Feb 16, 2003 | 07:46 PM
tdc's Avatar
tdc
ok lets start by your code 10 check and recheck your wiring on your intake i had the same thing and it was my wiring i had the wrong wires on the drivers side intake check your colors it`s got to be something easy buy your over looking it now your code 8 don`t your run wires in to the ecu for that maybe you got them backwards.it1s been a year since i did my swap but i know what your going through my biggest problom way i had the plug wires on backwards i sware the distibtor turned the other way.. well good luck
Old Feb 16, 2003 | 09:09 PM
dRuNk-dRiVer's Avatar
Default Re: zc swap pain in the rear coad 8 and code 10 (tdc)
yea wuts up wit that .... i got my swap 2 and my radiator fan wont turn on at all even after i been driving for a while.... but my engine light is fine its off.
Old Feb 17, 2003 | 06:31 AM
civicdragger818's Avatar
I just fixed my code 10 yesterday. I have a 88' dx with a LS-Vtec in it running a pr3 ecu. I had the exact same prob as you. Try taking the black wire on the IAT sensor plug and splicing into it and then taking it over to the black wire on the coolant temp sensor. Then reset the ecu and start it. See if this takes care of your prob. Thats what I had to do and it took me 2 weeks of research to find out that this prob is caused while going from DPI to MPFI if you dont have good connections in your wiring.
Old Feb 19, 2003 | 06:31 PM
Default Re: zc swap pain in the rear coad 8 and code 10 (civicdragger818)
Lets see pics of this. id like to try it on my car.
JapJunkie
Mar 22, 2004 11:05 AM
daniel89civ
12
Apr 6, 2003 05:36 PM
Pcart
Oct 17, 2002 05:59 AM
l
Mar 24, 2002 07:47 PM
