What kind of locking hood pins...?
Old Feb 16, 2003 | 10:55 AM
95si's Avatar
Default What kind of locking hood pins...?
besides this kind...
what kind of locking hood pins are tehre? i remember seeing another type, something very stealth and unnoticable.. any ideas?
Old Feb 16, 2003 | 02:57 PM
95si's Avatar
Default Re: What kind of locking hood pins...? (95si)
bump
Old Feb 16, 2003 | 03:24 PM
mattcxb18's Avatar
I would like to see those aswell!!
^bump
Old Feb 16, 2003 | 04:37 PM
tegon-gsr's Avatar
i want those hood pins where did you find that at
Old Feb 16, 2003 | 06:29 PM
95si's Avatar
Default Re: What kind of locking hood pins...? (tegon-gsr)
ebay.
Old Feb 17, 2003 | 01:12 AM
NirSpec1's Avatar
you can get those hood pins at pep boys... they look cool but suck *** they always break...
peace
Old Feb 17, 2003 | 09:12 AM
mattcxb18's Avatar
Does anybody know???
Old Feb 17, 2003 | 10:42 AM
95si's Avatar
Default Re: What kind of locking hood pins...? (mattcxb18)
it was almost flush, looked like a keyhole almost, like you would need a quater or something to turn it.
Old Feb 17, 2003 | 07:40 PM
mattcxb18's Avatar
ttt
Old Feb 17, 2003 | 09:10 PM
InevitableRace's Avatar
I have those hood locks on my CF hood for about a YR now and i love them...I painted the chrome part flat black and left the key part alone...You can't even see them from far away only up close...and they are better because if someone wants to see under your hood you can say i forgot my key...heheh...Like i do...
Ross
Old Feb 18, 2003 | 09:13 AM
95si's Avatar
t
t
t
Old Feb 18, 2003 | 11:03 AM
The G2 Racer's Avatar
I believe Sparco makes locking hood pins.
Old Feb 18, 2003 | 11:55 AM
Kwisatz Haderach's Avatar
Default Re: What kind of locking hood pins...? (The G2 Racer)
Nope, checked the Sparco USA website. They make normal hood pins, but not the kind you are looking for.
Old Feb 18, 2003 | 01:35 PM
Tbone's Avatar
Those are the ones I run.......here's a pic. Total pain in the butt to install.
Old Feb 20, 2003 | 08:07 AM
95si's Avatar
Default Re: What kind of locking hood pins...? (Tbone)
why so hard to install?
Old Feb 21, 2003 | 04:05 AM
Tbone's Avatar
Because the lock cylinder and the receiver both have to be at the exact same angles in order for it to lock(in all directions). If yuo notice on our hoods there not flat but curve, so when you install the receiver on the radiator/headlight suppoer housing you needto use some trickery to actually bend the mounting points to match with the cylinders in the hood, all while not making it to noticable to the naked eye(unless you dont care how it loooks) Then when actually putting the locks into the hood itself you run into a whole nother nightmare, the under side of my fiberimage hood has a skeleton around the outside edge, exacylt where you need to put the lock. The large washers you see in the pic go on top as well as on the bottom insde the hood so the locks wont pull through the hood. i had to drill the holes and then put a slot with a die grinder on the back inside of the skeleton to slide the wasker into the inside of it , so i could put the washer on the lock as well as the locking nut. I wish I had some better pics to show you what I'm talking about.
Old Feb 21, 2003 | 06:38 AM
UNCVLZD's Avatar
I think the ones you're looking for, the ones that you can turn with a quarter, are called "zues" fittings, or something really close to it.
Old Feb 21, 2003 | 09:48 AM
kikicamacho's Avatar
Default Re: What kind of locking hood pins...? (mattoien)
Dzuz fasteners is what they are.
Oops I mean Dzus.
[Modified by jcamacho, 10:49 AM 2/21/2003]
Old Feb 21, 2003 | 11:00 AM
Tbone's Avatar
The dzus(sp) are not locks though, anyone with a quarter can open them.
ralpheezy
Sep 19, 2004 06:33 PM
ViperRedCRX
23
Jun 6, 2003 10:45 AM
MikeyDB7
Apr 23, 2003 11:19 AM
tolowhb
Aug 8, 2002 10:36 PM
